Author Topic: Rattle At 2K RPM  (Read 954 times)
Offline lad
Rattle At 2K RPM
« on: April 11, 2021, 07:55:53 AM »
There’s a mad rattle when i’m at 2K RPM that sounds like a bag of empty drinks cans, coming from this genera area...
Is this a common thing? I remember someone mentioned a vibration where you feel your right foot to numb.
Maybe I forgot to tighten something?
'96 1100i
Re: Rattle At 2K RPM
« Reply #1 on: April 11, 2021, 08:02:12 AM »
I would look at all of the exhaust plumbing around there first. There isn't much else in that area that I can think of that would rattle. I guess someone could have had it apart and not properly spaced the swingarm bearings. Pretty unlikely though.
« Reply #2 on: April 11, 2021, 08:13:05 AM »
The universal joint is on the other side, if you have a center stand put it on there and rotate the back wheel, reef on the swing arm too.
Is it a tinny rattle or more of a clunk,
Wayne is probably right, exhaust.
Half a V9 Roamer
Online bmc5733946
« Reply #3 on: April 11, 2021, 11:31:30 AM »
I hope you are not riding at 2000 rpm, any time spent at this engine speed under load is close to if not lugging the engine. Guzzi's are happiest above about 3500 rpm. If this is happening at a standstill while free revving the engine, clutch lever pulled to bar you are probably hearing the clutch plates rattle, lever out could be slop between clutch plates and input hub on transmission or play in transmission, dogs, etc. on shafts.
Brian
1989 MILLE GT
2004 BREVA 750
1975  Convert
Offline pehayes
« Reply #4 on: April 11, 2021, 12:20:42 PM »
Should be a rubber cushion for the retracted sidestand.  Sometimes they fall out.
« Reply #5 on: April 11, 2021, 03:57:36 PM »
Loose exhaust baffle ?
Offline lucky phil
« Reply #6 on: April 11, 2021, 05:37:54 PM »
Rear wheel bearings. Use a wooden lever between the swingarm and the tire and gently lever the wheel to find the movement. You won't normally feel it by just grabbing the wheel and trying to shake it.
Ciao
Online John A
« Reply #7 on: April 11, 2021, 05:59:47 PM »
Slap the end of the muffler with the flat of your hand sharply. You can often replicate a rattle if it’s in the muffler
Offline lad
« Reply #8 on: April 12, 2021, 07:45:28 AM »
Brian
Thanks, i'll test that.
It happens just as i'm going through 2000, in 1st, 2nd gear, no lugging
'96 1100i
Online Chuck in Indiana
« Reply #9 on: April 12, 2021, 11:32:05 AM »
I had a similar noise that drove me crazy (ier)  :smiley: It ended up being a tweaked crash bar.
Albert Einstein
