Making sure that the throttle plate closed voltage is 150mV still makes sense. The TPS need a base line, and that number is the only part of the equation that seems to be almost universally accepted.
Would CARC guzzis have an O2 sensor, if so the o2 sensor controls the mix in closed loop operation. 15m and earlier ECU do not test the exhaust gasses.
