Author Topic: V7iii First Service Grumblings  (Read 1890 times)
Offline Githianki
« on: May 02, 2021, 05:00:54 PM »
So I'm finally getting around to doing my first service on my V7.  Everything was good, however as I had assumed, they overfilled my final drive, and to my surprise, they underfilled my gearbox at PDI.  Final drive took about 180ml out, but the gearbox only 350ml came out.  I also did it hot, so I know it all came out, I also let it sit for 2 hours after opening all the plugs.  I put the 500ml into the gearbox and will monitor, and adjust the final drive to the correct level.
And we wonder why people do their own wrenching on these bikes.
This is a pretty good dealership, so I'm surprised they missed it.
If you can beat them, arrange to have them beaten.
Re: V7iii First Service Grumblings
« Reply #1 on: May 02, 2021, 05:41:24 PM »
I’m the softest bloke around when it comes to forgiving understandable errors, but they need you to tear them a new arse...!
Offline Githianki
« Reply #2 on: May 02, 2021, 05:45:37 PM »
I'm with you Huzo,  I've bought 5 bikes total from these guys and they are a good outfit.   But they will be getting a phone call from me first thing when they open Tuesday.
« Reply #3 on: May 02, 2021, 05:45:43 PM »
I seen 350 in a bunch, almost like normal from factory. How much can you check in 1hr, that's all we had at PDI. Stick a tie wrap in, see oil, call it good there's no level plug. Supposed to put it on software too. How fast can you go, is what it is. At least nothing went wrong in the time.
Offline 80CX100
« Reply #4 on: May 02, 2021, 09:07:19 PM »
Unfortunately it's a common issue; when they translated the Service Manual from Italian to English iirc they referred to the rear diff as the "transmission", and to the transmission as the gearbox.
Most shops have the junior guys doing the fluids and if they're not on the ball and don't realize the funky translation to English, the larger amount gets dumped in the diff and the lower amount goes in the gear box (transmission),,, there have been a few posts about owners cooking their transmissions (gear box), shortly after servicing because of the low fluid level.
fwiw
Edit: After reading the op's post again and the amounts that came out of the diff and the transmission, that wasn't what happened here, fwiw.
« Last Edit: May 03, 2021, 06:21:55 AM by 80CX100 »
2008 California Vintage
2003 V11 Lemans
1979 G5 & 1980 Lemans CX100
Offline Clancy
« Reply #5 on: May 02, 2021, 09:27:58 PM »
When you drained the transmission did you have the fill screw cap open?
On my old V7-II, Michael (from Moto Moda - Pete Roper's business) and I found that if you drained the transmission with the fill cap on a vapour lock can occur stopping all the oil from draining out.
Cheers
Craig
« Reply #6 on: May 02, 2021, 10:09:25 PM »
It would be a huge oversight if the "jr" techs were not made 100% aware of the confusing terminology.
I was just at a shop where 5 V7's were unloaded and fluids (gearbox and final drive) are dumped, measured, and corrected as necessary.  That's a pro shop for you.  And yes, the customer pays for PDI, and it's as thorough as can be.  You can debate if it's necessary, it's the factory responsibility, any or all of it.  These guys check it as it's the only way to KNOW.
None of this "well, it's a factory fill, sorry your new bike is screwed, and it's a warrantee claim" stuff.
Offline kballowe
  • - Kevin the Great -
« Reply #7 on: May 02, 2021, 10:26:44 PM »
Don't feel like the Lone Ranger.   The OWNER of the shop where I purchased my first 1400 was the same guy that serviced it.  When I picked it up, he told me that he wasn't really sure how to check the oil on this bike.
I had to trailer it home because I couldn't get a ride to the dealer.   So I got home, drained out an extra quart and a half.
Rode the bike around most of the day, and then rechecked the oil level.  It was right at the fill mark.
I brought that quart and a half back to the dealer the next day, just in case they "shorted" someone else.
His response was "I told you that I wasn't sure how to check the oil on that bike".
Offline Githianki
« Reply #8 on: May 03, 2021, 06:34:57 AM »
I always pop the fill caps so everything flows.
Exactly KOF, these guys do that with their bikes as well, which is why I'm surprised that it happened.  Maybe they had an off day.  I'm not out for blood or anything with with the dealer, just want to let them know that it happened, as well as maybe let other folks here that it "might" happen to them too.
« Reply #9 on: May 03, 2021, 07:05:50 AM »
In your original post you refer to "they". They being the factory incorrectly filled the transmission and read dif, and the dealer didn't catch it?
As Guzzisteve mentioned, other than sticking something in there looking for a sign of fluid, I would doubt any dealer would actually drain, measure, then refill.
Except that KOF just said he just helped/witnessed Hamlin do it to five new bikes. Probably from experiences like this.
« Reply #10 on: May 03, 2021, 07:27:56 AM »
Okay, you are correct. I went back and re-read his post.
John Henry
Don't get me wrong, someone like him is an absolute exception to the rule. I bet there are very few others that do that, even some of the "good" ones. It's just not something that should reasonably be necessary.
Online Vagrant
« Reply #11 on: May 03, 2021, 07:45:06 AM »
I know the V7III has a nylon screen shoved up the drain hole. I can't remember if the V85 did or not. If so it needs to be pulled to drain properly and be cleaned.
2016 V7II, 2017 V7-III Blue special, 2022 V85 the fast red one! 2016 650 Versys
Offline Perazzimx14
« Reply #12 on: May 03, 2021, 08:01:44 AM »
Was it THE 1st service or the 1st time you serviced the bike?
If it was THE 1st service wouldn’t the rear drive, transmission and engine oils be factory filled??
2017 Road Glide Special
2020 Kawasaki KLX300SM
2016 Suzuki Van Van 200
Offline Githianki
« Reply #13 on: May 03, 2021, 08:19:39 AM »
Kev, you're absolutely right.  The fact that he does it to doublecheck the factory is telling.
@Perrazzimx14,  THE 1st service.  Just because it was factory filled, doesn't mean it was filled right.
Offline dave1068
« Reply #14 on: May 03, 2021, 08:31:07 AM »
My bike is further proof that not everything done at the factory is done correctly. Perhaps Luigi worked on both bikes on a friday....
I knew Jim when he worked as a tech at Twisted Throttle before opening up his own shop. Good guy-
Dave
-2020 Moto Guzzi V85tt travel
Offline Perazzimx14
« Reply #15 on: May 03, 2021, 10:20:31 AM »
Agreed but hard to complain to the dealer about what the factory did.
« Reply #16 on: May 03, 2021, 11:50:22 AM »
I kept my pre delivery certificate, it just says "Check all types of oil (engine, gearbox, transmission brake etc) so they just check to make sure the factory remembered to put some in, thats all you can expect I reckon
I would have been really nervous if I thought the dealer was changing fluids and was real happy to see less than 2 km on the odometer.
I'm sure the factory would have a fairly good method of squirting just the required amount in in seconds flat.
A tip when you are changing the oils, take the drain plug out first, the oil comes out quite slowly, then take the fill plug out, this keeps the discharge rate to a minimum until you have your hands/tools out of the way.
Half a V9 Roamer
Offline Perazzimx14
« Reply #17 on: May 03, 2021, 12:05:52 PM »
ALWAYS take the fill plug out 1st. If you remove the drain plug 1st then strip of otherwise eff up the fill plug trying to remove you cannot refill with oil.
At a bare minimum break the fill plug loose 1st before moving the the drain plug.
« Reply #18 on: May 03, 2021, 11:39:52 PM »
That's pretty strange logic  :grin:
Try it my way once, you won't go back.
Half a V9 Roamer
Offline Perazzimx14
« Reply #19 on: May 04, 2021, 04:09:57 AM »
So I used to do it drain plug 1st then open the fill plug seems like the natural order of things. Then year ago when changing the differential oils on my Toyota everyone was very explicit on open or at least break the fill plug 1st as its know strip or be corroded in place. If it does strip or you cannot remove it and you already drained the oil out you how do you refill it? I guess roll the vehicle over on its roof?
The massive outrush of a couple 100cc of oil from the rear drive is nothing a sheet of aluminum foil cannot corral.
« Reply #20 on: May 04, 2021, 06:43:44 AM »
That's maintenance 101 on old stuff. You never know when you might run into a problem, so why build bad habbits.
And like Peraz, I've never been overcome by the deluge from a drain plug.
Offline Perazzimx14
« Reply #21 on: May 04, 2021, 07:24:27 AM »
Oh goodie, a drain/fill plug debate. Much more entertaining than a tire or oil debate.
If a fill plug became damaged, or the threads in the housing, you're probably not going anywhere anyway until it is resolved, right?
Just sayin'. :popcorn:
John Henry
More often than not is the damage is to the head of plug and will strip so its not even removed from the housing. Or its corroded in place and cannot be removed. In either instance that's the problem. The plug is blocking the fill hole you cannot get oil in.
« Reply #22 on: May 04, 2021, 07:56:37 AM »
John Henry
Only if you drained it before you were sure you could refill it.
I mean long term it's still something you need to deal with, but if you've drained it, you need to deal with it RIGHT THEN AND THERE, not a few months down the line.
Online Ncdan
« Reply #23 on: May 04, 2021, 08:17:50 AM »
My question to him would have been “I need for you to expect to me what in the H do you mean by I DONT KNOW HOW TO CHECK THE OIL IN A MOTORCYCLE I JUST SOLD YOU”
How ignorant and irresponsible can someone be?
« Reply #24 on: May 04, 2021, 08:23:08 AM »
Never had any issues w/350cc drain, just enough to not have problems. Hey, and Guzzi saves 150cc oil at a cost to YOU.
No level plug is an issue they should have fixed by now. It would make PDI not an issue at a cost to dealers.
« Reply #25 on: May 04, 2021, 08:45:39 AM »
I think it comes down to things like barn finds that haven't been touched in forever, or applications that don't require service as often.
The logic is sound. If you always do it the one way (habit) then you'll never get bit by the exception (above).
If you always do it the other way (that's your habit) then you MIGHT someday get bit.
There's thousands of other things we build habits with - putting the kickstand up right away when you straighten out a bike, using the engine cut button to shut it down, pull on a wrench or ratchet instead of pushing on it, keeping a ratchet steady/straight onto or into a fastener to keep from rounding it, not carrying a screwdriver in your pocket...etc.
You can choose or not to follow these habits and maybe it will never effect you negatively, but that one time you don't pull up the kickstand (and don't have an electronic nanny), need to shut the bike off in an emergency and thumb doesn't automatically find the kill switch, push on a wrench and lose balance or bust knuckles when it brakes free suddenly, round off a fastener, or fall and puncture yourself with a screwdriver.... well then you lost.
So it's cool, I mean do it or don't. I was just explaining the why many are taught that to form a habit.
But I was directly answering your question. YOU CAN BE GOING SOMEWHERE TILL IT IS RESOLVED, as long as you didn't drain it with no way to refill it.
« Reply #26 on: May 04, 2021, 09:21:12 AM »
Kev, you do understand that I agree with you guys right?
No I couldn't get that from your response.
Not that it was important, it was just a matter of conversation.
Let's face it, there are a ton of things we learn over the years - some of which is ridiculous, some of which just doesn't matter, some of which is myth etc.
Most of which is probably not important right?
Offline Githianki
« Reply #28 on: May 06, 2021, 03:11:40 AM »
Funny, I do it the other way around so that it comes out with a rush.  I hope that anything heavier sitting in the bottom of the sump may be flushed out so it can be inspected in the light of day.
