Author Topic: loop 4 speed shimming  (Read 382 times)
Online lazlokovacs
« on: January 30, 2021, 10:25:46 AM »
rear shifter is a little bit (0.8mm) worn on the 1st gear side...
which means I should move the drum forwards
BUT there in no shim on the front side of the shifter drum.
Could I move a shim from the rear to the front end of the output (lay)shaft to compensate?
Cheers
