Author Topic: Norge Starter removal +  (Read 330 times)
Offline SemperVee
  • USMC Retired
« on: March 20, 2024, 10:00:28 AM »
 Wanting to add emergency quick start button before I need to on my 07 Norge with nearly 50 K miles.   I have the waterproof start button and double male adapter for the solenoid to wire to + side of battery but cannot seem to reach it under the fairing body.
Q:  Must the side fairing be removed to access the starter to get to solenoid spade?   Is there an easier way?  Never took off fairing body surrounding tank area.
Yes, already has "Startus Interuptus fix.
Thanks for ideas..
« Last Edit: March 20, 2024, 06:01:03 PM by SemperVee »
2007 MG Norge - Hi Ho Silver! - La Dolce Vita
CalSci Tall Windshield
Heli-Bars
Matris Fork + SAG set
Eibach Rear spring
Salamander HB ends
K&N  filter
StainTune pipe
Metal gas fltr
Givi Rear rack
Givi V46 Box and Rack
Startus Interuptus
Napoleon Mirrors
Grip Puppies
Re: Norge Starter removal +
« Reply #1 on: March 20, 2024, 10:14:00 AM »
Yes, they come off, one side then belly then other side. They go back on same way, one side then belly then other side.
Offline SemperVee
  • USMC Retired
« Reply #2 on: March 20, 2024, 10:15:39 AM »
Already ride with lowers and belly pan off.  Still cannot reach starter. Part of frame blocks getting to solenoid.
« Last Edit: March 20, 2024, 10:18:14 AM by SemperVee »
Heli-Bars
Eibach Rear spring
Salamander HB ends
K&N  filter
StainTune pipe
Metal gas fltr
Givi Rear rack
Startus Interuptus
Napoleon Mirrors
Grip Puppies
« Reply #3 on: March 20, 2024, 12:31:24 PM »
Tight fit but it comes back & swings out on back of starter, have to pull back into shifting arrangement & disconnect the wires.
That side plate comes loose w/3-4 bolts, disconnect shifter before tacking off.
« Last Edit: March 20, 2024, 12:34:10 PM by guzzisteve »
« Reply #4 on: March 20, 2024, 03:02:00 PM »
My Norge does not have the lowers, but I can get my starter off without removing the footpegs mounting plate.
Just the plastic cover.
Undo the electrical connections.
Two bolts and it falls off onto the floor.
Offline SemperVee
  • USMC Retired
« Reply #5 on: March 20, 2024, 03:24:41 PM »
Thanks Huzo,   Me & some needle nose SHOULD overcome.. I said "should" Just need to get to the solenoid wire connector.
Heli-Bars
Eibach Rear spring
Salamander HB ends
K&N  filter
StainTune pipe
Metal gas fltr
Givi Rear rack
Startus Interuptus
Napoleon Mirrors
Grip Puppies
« Reply #6 on: March 20, 2024, 04:52:36 PM »
Yeah, that connector is a bit frail.
I think I replaced mine with a more stout one, if I didn’t, I should have.
