Author Topic: BB Clutch Assembly - new title  (Read 2555 times)
Offline Scout63
Re: Gearbox Woes
« Reply #30 on: September 13, 2021, 05:51:23 AM »
The bike is crabbed and clutchless. I’m going to work it backwards checking as each component is added. Full reports to follow. Thanks everyone.
Ben Zehnder - Orleans, MA USA
Re: Gearbox Woes
« Reply #31 on: September 13, 2021, 08:19:34 AM »
 :popcorn:
Albert Einstein
Offline Scout63
Re: Gearbox Woes
« Reply #32 on: September 19, 2021, 09:23:48 PM »
I finally sorted it.  After pulling and installing the gearbox three times and dismantling the clutch twice I finally realized that I was installing THE RING GEAR BACKWARDS!!!.  It was overcompressing the clutch springs and, I suppose, hanging the clutch mount bolts up inside the bell housing.  I’m not sure about this but I can’t think of another reason why the engine wouldn’t turn with the gearbox installed. Since the clutch thrust piece was pushing up against the flywheel bolts, the clutch wouldn’t disengage.  All is fine now.  On to the next learning experience.
Offline jacksonracingcomau
Re: Gearbox Woes
« Reply #33 on: September 20, 2021, 06:04:38 AM »
Absolute respect
Takes a good man to post that
Suggestions
Change title to
BB clutch assembly
Might help the next bloke
Re: Gearbox Woes
Offline acguzzi
Re: BB Clutch Assembly - new title
« Reply #34 on: September 20, 2021, 10:05:33 AM »
have you checked the gearbox since it is out of the frame? It seems the most likely culprit to me.
« Reply #35 on: September 20, 2021, 02:51:02 PM »
 :smiley:
Albert Einstein
Offline Scout63
« Reply #36 on: September 20, 2021, 09:21:09 PM »
Thanks for the kind words Jacksonracingcomau.  They mean a lot. The bike is mostly back together save for the rear wheel.  Once I get it mounted I’ll check everything over.  The engine was turning over fine with the gearbox mounted with a bar turning the output shaft using half an old ujoint. I almost dropped the whole rig while uncrabbing the frame.  Too many diverse balance points.
« Reply #37 on: September 20, 2021, 10:35:47 PM »
Glad you sorted it, I end up taking apart just about everything I put back togetehr the first time to get it (hopefully) right on the second attempt..... glad to hear I am not the only one   :laugh:
« Reply #38 on: September 21, 2021, 01:23:07 AM »
Far too many egos won’t let people accept their errors, this site (and the Internet) is full of misinformation where “cures” are not even vaguely logical.
Yours might turn out to be common mistake, then attributed to some minor part to save author embarrassment.
My advice in taking on any job for first time
Follow manual and take pictures every step of way , phones make this so simple and if it ever comes to asking on net, those pictures make diagnosis so easy.
Crabbing so easy with hydraulic workbench, I’ve long forgotten what it was like without but I have hooks in joists at correct spots for tie downs to rear of bike. Lower bench to open the crab, raise to reassemble..
All should be good to go, but time double checking is not wasted, be happy before you ride it
Enjoy the ride
« Reply #39 on: September 21, 2021, 07:11:58 AM »
Of course, aircraft manuals are much better.. but..this is great advice. As an A&P, I'm licensed to work on everything that flies..(!)  from a free balloon to a triple 7. The FAA doesn't expect you to know every system of every thing that flies..but they *do* expect you to be able to look up the manual and follow it. I've mentioned before that I'm *not* a Guzzi mechanic. Guys like Charlie, Steve, Pete, etc. are Guzzi mechanics. They work on them every day, and know every part.
RTFM was my mantra when Austin first started working in the shop..and it always will be.
Albert Einstein
