Author Topic: Restoring Vintage Shock Absorbers  (Read 433 times)
Offline canuck750
  • Guzzi Hero
« on: March 15, 2019, 09:17:50 PM »
I have a couple sets of Ceriani shock absorbers that are period correct for many Italian motorcycles including my Laverda 750 SF1 and Benelli 650 Tornado to name a few. A couple pairs of these vintage shocks have suffered decades of corrosion to the hard chrome plates shafts. I tried several hard chrome plating shops in town but unfortunately these shops are not set up tp hard chrome the tiny shock absorber shafts, One shop quoted me $200 to set up their tooling and at least $100 to plate each shaft, Yikes!!
A shop foreman suggested I make new stainless steel shafts to match the originals, brilliant!
This is the shape of the original shock shaft after I cleaned the rust off
I was lucky to find 7/16" hard stainless steel rod and cut new sections to length and milled the ends and threaded the tips to match the originals.
I have a professional welder friend willing to TIG weld the stainless shafts to the carbon steel top caps,
I cut the old shafts off the caps, ground off the remnants of the old shaft and then made a jig to hold the new shaft in place to the original cap
Once welded up I powder coated the caps again and these shocks will last a life time
The stainless rod cost me under $15.00 and I used scrap steel to make the jig
It took a couple hours of machining, welding and painting but saved $100's!
1949 Guzzi Airone
1958 Guzzi Cardellino
1972 Guzzi Eldorado
1972 Benelli Enduro
1973 Guzzi V7 Sport
1973 Laverda SF1
1973 Benelli 650S
1974 Guzzi 750S
1975 Ducati 860 GT
1978 Moto Morini 500
2015 KLR 650
2016 BMW K1600
SOLD
1975 750 S3
Offline oldbike54
  • Moderator
  • Guzzi Hero
Re: Restoring Vintage Shock Absorbers
« Reply #1 on: March 15, 2019, 11:34:15 PM »
 Very nice work Jim , I am seriously impressed  :bow:
Transmit the message , to the receiver
Hope for an answer someday
Online Knuckle Dragger
  • Sunday Rider
« Reply #2 on: March 16, 2019, 12:52:36 AM »
Magnifico!
Severus bastardis
  • Guzzi Hero
« Reply #3 on: March 16, 2019, 04:23:33 AM »
I knew a winter project would come along sooner or later. :grin:  Nice work! :thumb:
  • Guzzi Hero
« Reply #4 on: March 16, 2019, 06:19:19 AM »
 :smiley:
02 Scura RC
79 G5
Sometimes it's easier to remember when you worked on something than where it is..
Offline cliffrod
  • Weekend Warrior
« Reply #5 on: March 16, 2019, 09:51:07 AM »
Very, very cool.  Thanks for posting.
1967 V700 Corsa
1964 Ducati 250
eccetera, eccetera...
Carolina Sculpture Studio Channel on YouTube-
Offline SED
  • Guzzi Hero
« Reply #6 on: March 16, 2019, 12:26:43 PM »
Nice work - great ideas there.  Thanks!    :thumb:
1983 LeMans III
1981 Monza
1947 Ariel Red Hunter
1939 Ariel Red Hunter
1937 Guzzi GTV
Offline canuck750
  • Guzzi Hero
« Reply #7 on: March 16, 2019, 03:34:04 PM »
Finished up the reassembly, Wolfgang Haerter at Columbia Car and Cycle in Naksusp B.C. had the new seal kits
The new stainless shafts are a tiny bit wider than the original so I had to ream out the centre of the cast slider a few thou, it's the part that moves with the shock action.
I filled them with 70cc of 5 weight fluid
And a repro decal to just smarten them up
And the loaner pair (much longer) can go back on the Laverda
Now the Benneli rear end sits like it should and the bike no longer wobbles on the centre stand. :thumb:
1949 Guzzi Airone
1972 Guzzi Eldorado
1972 Benelli Enduro
1973 Guzzi V7 Sport
1973 Laverda SF1
1973 Benelli 650S
1974 Guzzi 750S
1975 Ducati 860 GT
2015 KLR 650
2016 BMW K1600
SOLD
1975 750 S3
  • Guzzi Hero
« Reply #8 on: March 16, 2019, 04:54:26 PM »
Wow, nice job!
2017 V7III Special, 2013 V7 Racer
1977 Le Mans :grin: :grin:
1974 Eldorado  :grin:
2013 Ducati Monster 796, 2004 749, 1966 Ducati Monza 250
2007 Vespa GTS250ie
2016 BMW R1200RS, 1980/78 R100S, 1976 R90S ,1973 R75/5
2000 Kawasaki W650
1976 Honda CB400F, 1967 305 Super Hawk, 1968 CL175
Offline huub
  • Guzzi Mentor
« Reply #9 on: March 16, 2019, 05:48:54 PM »
nice job, next time you might try hard chromed shaft, over here it is easily available at 20 euro/meter,
it is more durable than the stainless
  • Guzzi Hero
« Reply #10 on: March 16, 2019, 07:20:01 PM »
Maybe so, but I'll bet it would be a bear to turn down and thread.. :smiley:
02 Scura RC
79 G5
  • Guzzi Hero
« Reply #11 on: March 17, 2019, 08:49:24 AM »
Beauty :thumb:
If you know something I really don't know, it will challenge something I presume
Offline Stevex
  • Guzzi Hero
« Reply #12 on: March 17, 2019, 09:27:53 AM »
Neat  :thumb:
Steve
1980 Le Mans II
2009 Honda CB1300S
2005 Aprilia Tuono
Chief mechanic to wife's 696 Monster
A 'gnat's cock' is an accurate unit of measurement.
Offline canuck750
  • Guzzi Hero
« Reply #13 on: March 17, 2019, 11:01:38 AM »
Good tip Huub, I may look for that for a pair of Ikons I have in need of new shafts. Do you know if it is available in metric diameters?
1949 Guzzi Airone
1972 Guzzi Eldorado
1972 Benelli Enduro
1973 Guzzi V7 Sport
1973 Laverda SF1
1973 Benelli 650S
1974 Guzzi 750S
1975 Ducati 860 GT
2015 KLR 650
2016 BMW K1600
SOLD
1975 750 S3
Online Tom H
  • Guzzi Hero
« Reply #14 on: March 17, 2019, 11:22:53 AM »
Nice Work!!
For the Ikon's, maybe try Ikon for new shafts rather than making them.
Good luck!
Offline huub
  • Guzzi Mentor
« Reply #15 on: March 17, 2019, 11:38:21 AM »
actually , over here ( netherlands) , that is the only sizes available
example;
https://www.indi.nl/nl-nl/p/aandrijftechniek/staal-en-kunststoffen/stafmateriaal-staal/as-materiaal-hardverchroomd/Hardchroom-as-12mm-3m-45836
metric sizes are probably harder to find over there, but it is available
machining it is no problem , if you have to cut threads you are in the base material,  not in the chrome layer
« Last Edit: March 17, 2019, 11:39:35 AM by huub »
  • Guzzi Hero
« Reply #16 on: March 17, 2019, 03:03:37 PM »
The only thing I *know* about in the states is Thompson Shafting, used with linear bearings. Good luck turning and threading that..  :grin:
02 Scura RC
79 G5
  • Sunday Rider
« Reply #17 on: March 18, 2019, 03:25:53 AM »
Hello sailor!  In need of a good (Thompson) Shafting are we?  What a classic name.....
Severus bastardis
Advertise your products today. All proceeds go back into this website.
Your ad will show up over 10,000 times daily!
