Author Topic: 2013 Norge Fuel Pump Relay  (Read 1323 times)
Offline NWrider
« on: February 12, 2019, 08:25:08 AM »
When the ignition sw is turned on the fuel pump relay chatters and the fuel pump doesn't run.   The starter will not activate, which I think must be normal as the fuel pump hasn't run to build fuel pressure.   Anyway, I'm hoping someone will know of a readily available replacement fuel pump relay.  The relay is: LI L5A 12V 30A 03-2012.
Re: 2013 Norge Fuel Pump Relay
« Reply #1 on: February 12, 2019, 08:50:27 AM »
If it is intermittent I would check the wire leads at the pump and the pins in the plug to harness. You should be able to swap relay w/another on the bike.
Offline NWrider
« Reply #2 on: February 12, 2019, 10:16:03 AM »
Well, I swapped relays with the same result.   :violent1:  In spite of the battery showing a full charge --- it had no capacity -- just a surface charge.  Removed the battery and jumped with the car -- started right up.   In the meantime, I'm going to install the MPH startus interuptus kit as a preventive measure.
