Author Topic: 02 cali ecm mount.  (Read 163 times)
Offline s1120
  • Guzzi Mentor
02 cali ecm mount.
« on: February 24, 2019, 01:30:47 PM »
So im going through the bike giving it a good check over, and noticed one side of the ECM bracket has no hardware. I can just nut and bolt it, but there is a bit of a space between the bracket, and the frame. Should there have been a bushing, or something between the ecm bracket and the frame?  Or was something mounted between it at one time? I dont want to mount it solid if it should be rubber mounted or something.  Also right next to the 3 termanal ECM diag connector, there is a small two wire barrel
 connector. Any idea what it should be for?
Paul B
Online John A
  • Guzzi Hero
Re: 02 cali ecm mount.
« Reply #1 on: February 24, 2019, 01:38:53 PM »
My '02 is buried inside a trailer under 8 feet of snow so I cant get you a pic but yes, both ends are bolted thru a rubber if I remember.
If only one end is supported it'll vibrate itself to death.
If you know something I really don't know, it will challenge something I presume
Offline s1120
  • Guzzi Mentor
« Reply #2 on: February 24, 2019, 01:42:32 PM »
The other end is fixed solid...  looks like its OE mount also..  Makes since about the vibes though..
Paul B
Online Tom H
  • Guzzi Hero
« Reply #3 on: February 24, 2019, 01:43:52 PM »
« Last Edit: February 24, 2019, 01:46:50 PM by Tom H »
Offline s1120
  • Guzzi Mentor
« Reply #4 on: February 24, 2019, 01:58:24 PM »
There should be a rubber stand off.
Support anti-vibration #93 22 13 30 4pcs. required
http://www.harpermoto.com/parts-lookup/2000-2009-moto-guzzis/california-ev-pi-cat.-1100-2003-2005/electrical-system-i-en-2-3-4-5-6-7-8.html
Hard to tell because the illustration numbers don't match the parts list...   but the ecm does have the 4 mounts [#6 in the picture..]  But if you look at the plate [#5] it shows a bolt and frame insert [ 9 and 11] on the left, but nothing shown on the right..
Paul B
Online Tom H
  • Guzzi Hero
« Reply #5 on: February 24, 2019, 02:32:03 PM »
Sorry, was looking at the picture wrong.
My bike was missing the one in your picture. My ECM had been replaced so I figured they forgot it or it fell off.
#11 in the illustration is a nut, 2 are required though I can only find 1 shown in the parts list.
I just used a nut and bolt to attach that ear.
Hope this helps.
Offline s1120
  • Guzzi Mentor
« Reply #6 on: February 24, 2019, 04:53:13 PM »
Hope this helps.
No problem,   After 25 years in the parts world the picture helped me.   So yours was missing also..  Strange. It looks like marks on the plate where a nut would have been, but there is no insert behind it at all..  If it was the auto world I would wonder if there was some kind of a service action to remove it for some reason..
Paul B
