Author Topic: Starter noise.  (Read 1691 times)
Offline gfritzmeier
Starter noise.
« on: July 07, 2019, 09:26:51 PM »
I've got a new recent noise when starting bike. I've got 2003 California and it's always started good. It still starts but recently it's making this tinny grinding noise when starting.  The noise is the symptom and wondering if any of you know what the problem might be?
Thanks,
Fritz
Ya don't have to believe everything ya think!
Ride All Day,Play All Night!
Re: Starter noise.
« Reply #1 on: July 07, 2019, 11:45:26 PM »
Valeo? Might be shedding its magnets into the armature. It's about the right period for that.
Re: Starter noise.
« Reply #2 on: July 08, 2019, 07:59:02 AM »
There is also a metal disk in there, I assume to help keep clutch dust out of the armature. I have seen that disk come loose and rattle around a bit when you crank the motor.
Either way, the starter needs pulled apart and disassembled. You can get rebuild parts for it.
Re: Starter noise.
« Reply #3 on: July 08, 2019, 08:02:06 AM »
For the Valeos? That's good news, I didn't know that.
Offline Rick in WNY
Re: Starter noise.
« Reply #4 on: July 08, 2019, 08:17:33 AM »
Mine did that last summer. The little disc came loose and it wound up arcing across the rotor.
I just bought a new Valeo from Harpers. Not cheap, but starters never are. The good news is, they are easy to replace.
Good luck!
Guzzi Owner since May 20, 2017
  2004 California Titanium
Re: Starter noise.
« Reply #5 on: July 08, 2019, 08:37:18 AM »
Good luck!
If you don't have to have a genuine Valeo, new knock-offs can be had for as little as $70.
Re: Starter noise.
« Reply #6 on: July 08, 2019, 09:08:02 AM »
Offline wirespokes
Re: Starter noise.
« Reply #7 on: July 08, 2019, 09:38:31 AM »
What everyone else said.
I've heard of that disc coming loose and shorting the armature so have safety wired mine in place.
When the planetary reduction gears run dry, they can make an awful racket, especially on the overrun.
Online Vagrant
Re: Starter noise.
« Reply #8 on: July 08, 2019, 09:58:04 AM »
Get it apart. Mine had a bake a lite type arm that throws the gear into the flywheel. It wore out.
