V-9 universal joint.
Topic: V-9 universal joint. (Read 986 times)
MMRanch
MMRanch
Evil wins if Good Men do Nothing
March 31, 2020, 09:56:00 PM »
I'm getting a lot of noise from the drive shaft area when shifting gears . Its like a Double Clunk , one from when I clutch and the motor quits pulling and the inertia spins the gears from the tire , then a second clunk when the clutch goes out and the motor starts pulling again.
I'm thinking a bad universal joint.
I took the rear chunk off when I was changing the back tire a few weeks ago. The rear universal joint seemed really loose but I couldn't see up in there .
So , how hard is it to put the drive shaft back in --- if I pull it out ? Do I have to remove the swing arm to put the drive shaft back in ?
Last Edit: March 31, 2020, 09:59:20 PM by MMRanch
2016 V7-II Stone
pete mcgee
Gaggle Mentor
Re: V-9 universal joint.
Reply #1 on:
April 01, 2020, 12:19:53 AM »
Put it up on the centrestand, put it in gear, how much movement backwards and forwards of the rear wheel?
You mentioned "loose" I assume that was in a rotational sense, something like 2 splines worth of movement before you felt load?
Any vibrations when riding or when going on/off the throttle.
How many miles on the bike?
kballowe
- Kevin the Great -
Reply #2 on:
April 01, 2020, 09:39:59 AM »
Be sure to let us know what you find out.
My new V9 Bobber is like that.
guzzisteve
"Just Ride It"
Reply #3 on:
April 01, 2020, 10:32:37 AM »
A pic from manual shows the shaft removed before the swingarm, I'd say it comes right out the back.
MMRanch
MMRanch
Reply #4 on:
April 01, 2020, 11:49:11 AM »
The bike only has a little over 4,000 miles on it. two weeks ago I changed the rear tire and removed the final drive while I was that far along into it. It was just a little tricky getting the final drive unit plugged back into the drive shaft - as the rear universal joint seemed to obey gravity instead of me !
I thought it looked like the entire shaft would just pull out with a little tug. Putting it back in might require some special trick ?
The V-7II diagram shows only one universal joint and I wonder if that is a better plan ? The V-7II don't have that clang either !
I put it in gear w/tire raised and listened with a stethoscope w/motor running and that rear universal joint is the problem area.
So , Should I just call it a design flaw ?
I wonder if the drive shaft from the V7 would fit or if there is a way to semi-lock the rear universal joint (like putting it in a rubber sleeve) or ( rubber insert in the workings of that rear joint) (Duck-Tape
Last Edit: April 01, 2020, 12:02:48 PM by MMRanch
2016 V7-II Stone
MotoG5
Reply #5 on:
April 01, 2020, 11:56:08 AM »
So is my new Bobber. The clunk is common to every Guzzi I have owned. The loudest by far was the Stelvio. The rear wheel off the ground rotational check is a good rule of thumb check. Its not how loud it is its how far it spins before it clunks again. The noises should be with in a short distance of each other. I really doubt you have anything to worry about. Check it now and then ride for a while and check again and see if there has been any change. If its going south you will also start to hear more than just a clunk. Usually heavy vibration as the bike is slowing down with the clutch pulled in.
Nebraska MGNOC State Rep
MMRanch
MMRanch
Reply #6 on:
April 01, 2020, 12:05:20 PM »
My first Goose is/was , The V7II , its slick as a button no CLICK - CHUNK - CLANK , smooth as a chain drive , I expected them all to be like that ! Never had any experience with a shaft drive bike either
Last Edit: April 01, 2020, 12:09:57 PM by MMRanch
2016 V7-II Stone
pyoungbl
Reply #7 on:
April 01, 2020, 12:14:58 PM »
The V9 had two universal joints, one on each end of the drive shaft. The swingarm has a dogleg to allow wider tires than the V7i or V7ii version. A V7ii shaft won't fit. I seriously doubt that you have a bad U joint after just 4K miles. Pulling the swingarm is not a big deal. Then you can take a look at the entire drivetrain just to make sure. I think it will prove to be very difficult re-installing the driveshaft with the swingarm still in place, only because the tranny end U joint is certain to not cooperate. Before you get too worried you can measure the actual wheel play and then compare yours to others. There has to be a bit of play in the drivetrain due to the various gears involved, the U joints, and the cush drive.
'13 V7 Special (red/white)
