Author Topic: '98 V11EV Rocker Clearance  (Read 1247 times)
Offline n3303j
  • Ron Cichowski
« on: May 27, 2020, 08:09:11 AM »
Been running 0.004" Intake / 0.006" Exhaust since I got it and all is fine.
Like most others I'm confined by lack of open camping and lodging facilities. So, what the heck, might as well clean the motorcycles.
Turns out the "Blue Goose" has a placard on the fuel tank that I never thoroughly examined. It had basic tuning specifications. (I always used the Shop Manual)
Intake 0.002" / Exhaust 0.004" on the factory placard. These valves are stable enough to be set this close. Might be a bit quieter?
So where did all these varying numbers come from? Any reason not to set to the close figure and recheck clearances each oil change?
Maybe I should spend more time waxing and less time reading. Usually tank stickers are stupid California stuff like "Don't eat the battery, Don't run in closed garage, Motorcycle parts are carcinogens, etc)
Bikes Are cLeaner then they have been in a long time and all the fussy bits have been properly dealt with.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
jwinwi
Re: '98 V11EV Rocker Clearance
« Reply #1 on: May 27, 2020, 08:21:21 AM »
The tighter clearances were  to satisfy noise regulations (European only?) EDIT: US Only. She'll run much better at .004 and .006.
« Last Edit: May 27, 2020, 09:59:21 AM by jwinwi »
Online PeteS
« Reply #2 on: May 27, 2020, 09:56:38 AM »
The tighter clearances were only to satisfy noise regulations (European only?) She'll run much better at .004 and .006.
+1. It will run better and cooler too. Consider the '70s twins were spec'd at .006" and .008".
Online BMCMOTO
« Reply #3 on: May 27, 2020, 11:17:18 AM »
Some of the early square heads called for .009 and .009, Mille and Cal III for example, if memory serves, so don't be afraid of running them a bit loose.
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
Online Tom H
« Reply #4 on: May 27, 2020, 11:21:02 AM »
Per Pete Roper:
"Anything squarefin? 4 thou inlet, 6 exhaust. Roundfin? 5 & 7."
Offline s1120
« Reply #5 on: May 27, 2020, 12:17:34 PM »
Other then a new motor seating in...  Anyone ever see a guzzi tighten valve gap??  Seems most just loosen a tick
Paul B
jwinwi
« Reply #6 on: May 27, 2020, 01:51:18 PM »
Exhausts will tighten up, Intakes will get wider due to deposits on the face of the valve.
« Reply #7 on: May 27, 2020, 02:59:40 PM »
                                                        Loose valves save lives
 Wait , is that right ? <scratches head>
Offline Vagrant
« Reply #8 on: May 27, 2020, 03:26:15 PM »
only owned 12 over the last 48 years but never had to loosen one yet.
