Guzzi california EV1100I was underneath it today and noticed a small amount of oil gathering around a small hole on the underside of the swingarm on the right side. Is that bad?😢
Thanks guys.Yes the leak is just gathering around that hole. Nothing dripping to the floor. I removed the gearbox filler nut while on the centre stand and oil didn't come pissing out so I know it's not over filled.The oil was changed just recently and I know from my experience of BMW'S that some people make the mistake of filling on the side stand resulting in over fill. My first thought was rear main seal. Tell me it isn't so😔
Check your PM (messages)
Have replied but don't recognise the number. Just wondering where you are as don't want to incur a big phone bill
So, I let my EV sit for 6 months and came back to it. Started it and it dripped a little oil then stopped. Hasn’t dripped again. Great. Just needed a good running. But then the 92 K75 S started dripping a few drops a week. Since it’s not British I figured it needed to be fixed, so I bought the pieces to do a rear main seal job. But then I stuck my finger in the oil and smelled it. That’s not engine oil it’s gear oil! So I bought new seals , etc. for the box. Before I started the job, I went to Autozone and was convinced to try Blue Devil Trans. Sealant. I know it’s supposed to be snake oil but since it costs twice as much as anything else, it must be good . Right? It called for one ounce so I put in two. Damned if it hasn’t leaked a drop in almost a year! A lesson here? Sniff your oil and if the leak isn’t too bad then maybe give the snake oil a shot before tearing it all apart.🥃🥃🥃
If it smells like gear lube the most likely cause is the clutch push rod seals. There's an o-ring fix for that.Use the search function ..
Leak back at the swingarm - not sure that would be clutch pushrod seals...
My jackal leaves a drop or two out of the vent hose from the tranny.
If the small hole is on the bottom of the swing arm and underneath the area where the universal joint would be the small hole may have a set screw Allen head type in there to hold the outer race of the bearing from rotating check that out you could easily plug the hole with a dab of silicone. TOMB
