I want to lower my tall 1991 model R100GS a slight amount, perhaps no more than 3/4". I'd like to be able to reach the ground without using my boots with the thick soles.
Unfortunately, I cannot take the conventional approach to this, ie, sliding the stanchions up thru the triple trees, because:
a. they'll only slide 1/8" before hitting the handlebars.
b. if I raise the handlebars with spacers, to permit raising the stantions 3/4", the tops of the stanchions will hit the dashboard at full left or right lock. So shortening the forks (lowering the bike) seems to be my only solution.
Anyway, give me your opinion on the mod as shown in this video. 3/4" isn't much, and I can probably drop the rear the same amount playing with shock preload. If not, Ted Porter at The Beemershop can shorten it 3/4". Start video at about 3:25.
This is the only video I could find that discussed shortening damper rod forks.
Bob
https://www.youtube.com/watch?v=OoMQtK4M42M
