Author Topic: Don't Squirt De-Oxit onto Connector Seals  (Read 784 times)
Offline TommyR
« on: July 07, 2021, 11:48:18 AM »
Wonderful . !! Thought I had a bad ECU connection on my MY17 Stelvio NTX. Took out both ECU 38 pin plugs and cleaned per instructions with De-Oxit. Worked well ..except it caused the little three lip connector seals on each block to expand and go all rubbery and soft. I guess they are Viton which i guess sucks in the solvents in the De-Oxit. Thus, it was impossible to reinstall either ECU connector without bunching up and tearing the seals. Totally pissed off i threw the towel in and went to bed. Next morning ..wowza!! The seals had dried out and tightened back up, thus making the re-connections a doddle. After all that i cleaned the ECU earth contacts...and kaboom, flippin bike still would not start..dead as a doornail. Then as if by magic, i discovered the multi pin connector into the back of the dashboard was loose.... What is it about bloody Italian motorbike electrical systems and Magnetti Marelli that is just so utterly bad???
Re: Don't Squirt De-Oxit onto Connector Seals
« Reply #1 on: July 07, 2021, 12:05:03 PM »
You should call the 800# and tell them what you think!! If more riders would do this instead of wooing over the V7 range you might get results.
IT is better than those Molex connectors from my era.
Online Vagrant
« Reply #2 on: July 07, 2021, 12:23:58 PM »
You coud have said that a month ago!
I had to pull the tank on the V85 and the 4 or 5 pin connector in there did the same turn to jello trick on me. I honestly don't remember  spraying it but I bet I did as it is my habit. Absolutly no way would it go back together. I had a big varity pack of new conectors so I stole one from there. Now I know! Too bad I'll probobly forget by the next time!
