Author Topic: 3D printing rubber part ??  (Read 1733 times)
Offline dsrdave
« on: August 05, 2021, 09:42:23 AM »
I’m having difficulty finding the rubber piece between the velocity stack and air cleaner on the stornello 125.  Is it possible to 3D print something like that??? Any help or advice is appreciated
Thx dave
Re: 3D printing rubber part ??
« Reply #1 on: August 05, 2021, 10:13:27 AM »
I'm also interested in a possible part print of #25:
Just a small piece of gray plastic.
Offline Bisbonian
  • Living the Dream
« Reply #2 on: August 05, 2021, 04:29:38 PM »
You might be able to do it with TPU but I'm really not sure, there is likely a better filament to get the job done.
I've used TPU to print tires for my creeper wheels, pullies for my bicycle chain, and feet for my ladder but that's about it.
TPU is fairly flexible but I'm not sure how it would hold up long term to vibration and weather. I still have most of spool left and I'd give it a try if you have good dimensions of what you're looking for.
Offline Bisbonian
  • Living the Dream
« Reply #3 on: August 05, 2021, 04:31:13 PM »
I think there is any number of filaments that can be used for that. ABS might be best but I haven't tried that yet, I'd probably start with PLA+ and then maybe move on to PETG for outside use in the weather.
Offline Rick4003
« Reply #4 on: August 06, 2021, 06:56:27 AM »
Thx dave
It should be quite possible to print in TPU. I have used it for several different parts. Do you have some good measurements or pictures of the part needed? it would likely need to be drawn up in CAD before you can print it. Unless someone have already made one and shared the parts, which is unlikely.
Moto Guzzi Ambassador - 1967
Yamaha FZR 600 - 1996 - SOLD
Offline dsrdave
Re: 3D printing rubber part solved!!
« Reply #5 on: August 26, 2021, 05:50:23 PM »
A BIG thank you to Adam for printing the velocity stack boot
It looks and fits great !!
« Last Edit: August 26, 2021, 07:01:09 PM by dsrdave »
Online Ncdan
« Reply #6 on: August 26, 2021, 07:05:56 PM »
Could you 3D guys possibly print the rubber piece that’s used in the turn signals on the EV style bikes? You know the ones that are always breaking due to the material getting hard and brittle. If so I’ll take 4👍
« Reply #7 on: August 26, 2021, 08:28:38 PM »
And I hear the spares are out of production.
Offline dsrdave
« Reply #8 on: August 26, 2021, 08:30:31 PM »
Is the EV turn signal the same basic design as the griso and quota ones ??
If so I found a fix …….
Online Ncdan
« Reply #9 on: August 26, 2021, 08:49:21 PM »
Not sure about that Dave. I have an 02 Stone if that helps.
Offline Bisbonian
  • Living the Dream
« Reply #10 on: August 26, 2021, 10:18:48 PM »
You'd have to send a pic and diagram with dimensions. I'd be willing to give it a try.
Offline dsrdave
« Reply #11 on: August 27, 2021, 02:50:19 AM »
Post a picture of the stone turn signal mount please
Thx dave
Online huub
« Reply #12 on: August 27, 2021, 04:13:00 AM »
at work we use something called ninjaflex to 3D print flexible parts.
amazingly solid stuff , would be perfectly suited for carb boots etc.
« Reply #13 on: August 27, 2021, 07:19:20 AM »
I am pretty certain that it is not the same.
The EV turn signal rubber and a metal hook cast into the base of it. The rubber gets brittle and the hook comes out.
Offline dsrdave
« Reply #14 on: August 27, 2021, 09:28:18 AM »
Yes, that sounds different.  The griso/quota and others have notches in the plastic extensions and when it dries out they break off
Online Ncdan
« Reply #15 on: August 27, 2021, 10:20:17 AM »
I can’t send any dimensions. Maybe if one could be sent to you, would that help?
Offline Groover
    • Scooteropolis
« Reply #16 on: August 27, 2021, 11:02:28 AM »
Sort of related, this got me intrigued and found this on Youtube:
https://www.youtube.com/watch?v=uR_xVABJhig
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline dsrdave
« Reply #17 on: August 27, 2021, 11:45:08 AM »
That looks very similar to what I had. I took mine apart, cut the stem to reduce bouncing around and the lever arm. Sanded both surfaces flat, cleaned and expoxied them back together. I found some 1-1/8” shrink tube with hot melt glue on the inside. Slipped that over the stem and used the heat gun. So far it’s stood up well. I don’t know how long term this will be but, so far so good!!
Hope this helps
Dave
