Author Topic: bike lift  (Read 1751 times)
Offline rudyr
bike lift
« on: March 17, 2022, 07:49:25 PM »
weeks ago, I call a guy that makes a bike lift, saw it on youtube it seems to work.  he never got back to me. so to nite  I took a old chicken house pully, pulled the roller off and some 1" strap connect roller on one end and connect the other end to 1" square tubing and then and then I installed a d ring about 8" down from the roller which I install on the end.  I have a min 500 lb. come a long.  hook the one end of the come along to d ring and run the  small chain over the roll on top of the  1" sq. tubing.  hangs down about 6' which come a long hook connect something on the lower end of bike, and then crank away on come a long.  I really think it's going to work.  to late tonight to try it.Rudy
Offline Ncdan
Re: bike lift
« Reply #1 on: March 17, 2022, 08:18:02 PM »
I hope it won’t be one of those “hay y’all watch this” moments Rudy😂
Post some pictures so we’ll have something to go by👍
Offline rudyr
Re: bike lift
« Reply #2 on: March 17, 2022, 08:57:35 PM »
let me make sure it will work.  I know it will work.  I'm going to put a Harley kick stand base on the of my bike lift sq. tubing 3/4' sq. tubing inside my 1' sq tubing.  that way lift rod as long as I want. collapse 3/4" into the 1".  then I will slide the lift rod into a length of tubing under the muffler on lift side of my v85.  the little come a long you can hold in one hand., just put in saddle bag. that my plaine. Rudy
Offline SoCV
Re: bike lift
« Reply #3 on: March 17, 2022, 09:00:29 PM »
 Rudy , applying for a patent might be a good idea  :thumb:
Almost 900,000 in a little over 8 years in two .
RIP Mike Prentice
Offline ridingron
Re: bike lift
« Reply #4 on: March 17, 2022, 09:12:19 PM »
Hope it is more successful than Mr. Nevada's attempt.   :grin:
Re: bike lift
« Reply #5 on: March 17, 2022, 09:20:08 PM »
I used leftover parts from when I was in the home medical equipment business. A Surehands lift and care systems rail and trolley and a chain hoist. Got me some fresh skins on the T7 headed for the Buffalo river area Sunday. 1st stop RUSH  :thumb:
https://www.surehands.com/products/ceiling-lifts
« Last Edit: March 18, 2022, 07:49:06 AM by Guzzistajohn »
Offline rudyr
Re: bike lift
« Reply #6 on: March 18, 2022, 04:33:18 AM »
John funny you mentioned hospital stuff. in my rent house repair, someone left a new hospital bed with the tubing. I used it for my lift.  John if I'm round I ride up.Rudy
Re: bike lift
« Reply #7 on: March 18, 2022, 06:36:38 AM »
Sounds good Rudy. Still got my number?
Offline rudyr
Re: bike lift
« Reply #8 on: March 18, 2022, 12:30:28 PM »
it works, really well.  and I tipped it over on a little hill. I just had a little block of plywood under the leg.  no scratches or bends either.  guess I will need to build some kits and call it a Tank Track lifter, that can be used for other things.  that way may I won't not need product liability.  I used the kick stand bracket, strongest pica of iron on the frame.Rudy
Offline dguzzi
  • Sorry, I'm woke so I'll be quiet.
Re: bike lift
« Reply #9 on: March 18, 2022, 06:57:53 PM »
  Is the trolley part made like heavy uni-strut?
'03 EVT
'87 Cagiva
'72 Commando
'71 Commando
'90 Miata
'16 Mustang
Re: bike lift
« Reply #10 on: March 18, 2022, 08:13:42 PM »
The track is like heavy uni-strut. the trolley rolls in the track. The track is hanging from uni-strut above the ceiling joists connected bt a strut nut and 3/8 all thread
« Last Edit: March 18, 2022, 08:15:56 PM by Guzzistajohn »
Offline rudyr
Re: bike lift
« Reply #11 on: March 18, 2022, 10:17:39 PM »
I connected pully roller between to pica of 1" flat strap then that to the i" square tubing.  to cute cost going to look for a heavy for a heavy duty 1" ratch strap.  then look for a good heavy duty office chair roller, to take place of the puller roller. X 2 model, so to speak. Rudy
Re: bike lift
« Reply #12 on: March 19, 2022, 05:05:30 PM »
Hey Rudy, see you down in the holler tomorrow  :thumb:
« Last Edit: March 19, 2022, 05:05:57 PM by Guzzistajohn »
Offline rudyr
Re: bike lift
« Reply #13 on: March 20, 2022, 12:48:58 PM »
John: I’ve been gravel road but didn’t go down Rush.  Didn’t have bike lift.  Eating yellville eating busker meat loft sandwich.  We must have missed one another one’ll it’s really good for a ride. Think I will ride to mt. View on my
 Home.Rudy
