Good read, thanks.Now, off topic, but....Question, what is being accomplished when varying the amount of fluid in your forks?
I was under the impression that the only purpose for the height adjustment on the spring was to allow centering a loaded bike on the travel range of the shock absorber. Object being to avoid topping or bottoming out the shocks on road irregularities. It was not to alter ride "quality".
It depends on the design and sophistication of the forks. Forks with only rebound damping adjustment primarily depend on the valve opening or in primitive forks just a hole in a tube so minimal effect of the amount of fluid. It will affect compression damping though as more fluid means less air space so compression damping is increased (stiffer ride). Opposite effect for less fluid.Pete
