Author Topic: Hole in right side exhaust header  (Read 1646 times)
Offline tonyduc
    • Staccato Cycle
« on: June 24, 2016, 10:49:01 AM »
All
I purchases a full Mistral exhaust system used a couple of years ago for my T3 project bike. Now I am ready to install, it is in great shape  but there is a small hole that looks purposely drilled on the right side header piper (in pic near the engine mount bolt). Is there a reason why one would do this, right side cylinder running hot on the donor bike? Would JB Weld likely hold or should is a small weld recommended?
2011 Stelvio -white
1976 T3
1996 Ducati 900ss CR
2017 Yamaha XT250
1966 Ford Bronco
Former
1969 Ducati 450 SCR
1984 California II
07 Honda VFR
71 CL350
08 Ducati 848
05 Ducati M620
80 Yamaha XS650
73 Suzuki TC100
Offline RinkRat II
  • Lake Powell AZ
Re: Hole in right side exhaust header
« Reply #1 on: June 24, 2016, 11:01:59 AM »
 Well most likely for the safety wire :evil:  Seriously a good tig welder could fill that but beware that may be the tip of the iceberg, corroding from the inside. Good Luck!
     Paul B :boozing:
« Reply #2 on: June 24, 2016, 11:03:54 AM »
 Maybe an attachment point for a sensor ? No JB Weld won't stand the heat .
« Reply #3 on: June 24, 2016, 04:11:16 PM »
I'd weld but in case it is not man made, I'd open it up incrementally with a step-drill to get past weakened edges to full thickness steel.
Todd.
Offline atavar
« Reply #4 on: June 24, 2016, 05:20:47 PM »
Being the cheap lazy cuss that I am I would prolly put a really short small sheet metal screw in it and call it good.  lol
Offline Markcarovilli
« Reply #5 on: June 24, 2016, 05:38:13 PM »
:1:
Mark
