Author Topic: 2014 Stelvio 1200 8v - What is this thing?  (Read 3072 times)
Offline skimbrie
« on: December 27, 2016, 06:11:51 PM »
I was replacing the oil pressure sensor when I noticed this thing towards the front of the block under the alternator. It looks like brass and it is roughly spherical and apparently hollow. It has a large opening towards the back of  the engine and small hole on the  top. At first I thought it was some loose part that fell down into that spot but it is quite solidly fixed in place and very greasy.
The reason I am changing the sensor is it seems to be the source of a nasty oil leak. But this thing looks like it could be some sort of breather fitting or something and might have something to do with the leak.
Here's one close up picture and another from further back showing the location.
Any help is appreciated.
-Scott K.
-Scott K.
'20 v85tt
Re: 2014 Stelvio 1200 8v - What is this thing?
« Reply #1 on: December 27, 2016, 06:46:11 PM »
Do you have a workshop manual?
« Reply #2 on: December 27, 2016, 06:51:59 PM »
Are you sure it hasn't corroded to the block?
« Reply #3 on: December 27, 2016, 07:11:29 PM »
<scratching head> Looks like a pecan to me.. :smiley: :boozing:Maybe a hickory nut?
Offline skimbrie
« Reply #4 on: December 27, 2016, 07:40:40 PM »
I have a shop manual and a parts catalog and I couldn't identify in any of the exploded views or photos.
I pried on it with a screw driver but it ain't moving - at least not with the force I was willing to apply.
When I first saw it, I too thought it was some kind of nut (as in tree, not as in "Guzzi Rider").
-Scott K.
'20 v85tt
beetle
« Reply #5 on: December 27, 2016, 08:07:53 PM »
I declare it a foreign interloper. Sanction with extreme prejudice.
« Reply #6 on: December 27, 2016, 08:34:07 PM »
Christmas candy melted on the block.
Offline Green1
« Reply #7 on: December 27, 2016, 08:58:37 PM »
Looks like a brass fitting or hex nut from an old sensor,little bit of brake cleaner to clean it off may make it easier to identify
Never argue with an idiot, people watching can't tell the difference
« Reply #8 on: December 27, 2016, 09:14:51 PM »
 It's the head of a thonorken bolt.  Absolutely vital that you not change the adjustment.
« Reply #9 on: December 27, 2016, 09:16:43 PM »
Sort of like the sacred screw.
Offline leafman60
« Reply #10 on: December 27, 2016, 09:18:02 PM »
Be careful.  The motor may fall out if you remove it! The Italians may have improvised and chucked that in there to hold something important.
Or, maybe its something else that has vibrated loose and fallen down there.  Some time in the future on a dark and lonely road, miles away from civilization, you may discover the purpose for which the object was intended before vibrating out.
Offline Porterhouse
  • GRiSO / Stelvio - A One and-a Two
  • GRiSO, he speaks to you, no?
    • the GRiSO ghetto
« Reply #11 on: December 27, 2016, 10:52:37 PM »
I could be wrong but I'm pretty sure that's the Fetzer valve.  You can have at it with some 3-in-1 oil and some gauze pads, but you're probably gonna need 'bout ten quarts of anti-freeze, preferably Prestone. No, no make that Quaker State.
That ought to do the trick.  :thumb:
GRiSOghetto - all GRiSO, all the time...  |  Life ain't easy for a boy named Sue - RIP my best friend...
Offline gearman
« Reply #12 on: December 28, 2016, 03:30:49 PM »
Grab it with a pair of pliers. Pull it out. looks like an interloper.
