Author Topic: CARC and Transmission Oil  (Read 7117 times)
Offline derek533
« on: March 08, 2017, 05:39:56 PM »
Has anyone with a big block had any experience with this stuff?  It's so easy to find around here but I can't tell if it meets all the specs.
http://lucasoil.com/products/gear-oil/synthetic-gear-oil/lucas-sae-75w-90-synthetic-gear-oil
Anyone know?  Thanks
06 Breva 1100
Married, 3.5 kids, and very blessed.
Offline lti_57
  • Directly above the center of the Earth
Re: CARC and Transmission Oil
« Reply #1 on: March 08, 2017, 05:47:58 PM »
More then likely
I am Big Fan of red line heavy Duty Shock proof my Self
What does your Manual say ?
2007 Guzzi Griso
1992 BMW K75
Offline jcctx
« Reply #2 on: March 09, 2017, 09:09:30 AM »
Bet you could stick 10W40 in both places and neither you or the bike would ever know the difference!!!
« Reply #3 on: March 09, 2017, 10:23:56 AM »
Yep, that's probably right - you could put engine oil in your transmission and gearbox and they'd be just fine.    Having gear oil that's different than engine oil is just a plot from the oil companies to make more money!   :rolleyes:  :shocked:
stormshearon
« Reply #4 on: March 09, 2017, 04:57:12 PM »
I am running that in my Stelvio. So far it seems fine - and based on what I read in the manual and on the label it meets or exceeds specs.
Offline derek533
« Reply #5 on: March 09, 2017, 11:06:45 PM »
Thank you so much.
See fellas, was that so hard?   :grin:
06 Breva 1100
Offline ITSec
« Reply #6 on: March 10, 2017, 02:40:06 AM »
As always, the key thing is whether it meets the specs. Ideally, a gear oil that meets the specs for both straight-cut gears and hypoid gears will allow the use of the same product in both the gearbox and final drive so long as the weight range is also appropriate.
Lucas could spend a bit less space congratulating themselves and a bit more speaking to specific applications (the tech sheet is a bit less tech than sheet), but it's decent stuff and a reasonable choice. I can't recall anyone blaming Lucas oil for a failure.
Should anyone want the original specs from AGIP for the CARC lubes for a baseline reference, here are they are:
http://people.delphiforums.com/ITSecurity/Norge/MP%20oil%20specs.pdf
http://people.delphiforums.com/ITSecurity/Norge/MPS%20oil%20specs.pdf
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
« Reply #7 on: March 10, 2017, 07:56:35 AM »
THX for that.
Offline derek533
« Reply #8 on: March 12, 2017, 04:36:37 PM »
Thanks and you are right.  The tech sheet sucks that Lucas puts out.
06 Breva 1100
Online RinkRat II
  • Lake Powell AZ
« Reply #9 on: March 12, 2017, 05:03:44 PM »
 Sorry guy's , I guess I don't know what your looking at but the spec sheet for the lucas product and the agip are almost identical.
 Exceeds GL5, mil specs the same , flash points, viscosity index etc . Looks like it fits the bill, where am I going wrong??
   Paul B :boozing:
Offline Huzo
« Reply #10 on: March 12, 2017, 08:50:24 PM »
   Paul B :boozing:
I sorta wonder why this needs proving and re proving. If I wasn't sure what to use, I'd just find someone who hasn't managed to destroy one in 100,000 miles and just use what he does. Put the stuff in and ride.
Offline ITSec
« Reply #11 on: March 12, 2017, 09:36:15 PM »
If that's the criterion, then my 122,000 mile Norge (new in 2011) has used Mobil1 75w90 in both gearbox and final drive for most of its life, and ELF/Total 10w60 (and more recently, Liqui-Moly) in the crankcase. It's still doing nicely...
ITSecurity
Offline Huzo
« Reply #12 on: March 13, 2017, 02:02:25 AM »
Well that's a slam dunk. I'd take your advice without hesitation if I was looking for guidance. I use Motul 7100 in the donk and Motul 80w90 in the gearbox and bevel drive. Never had anything else from new and gearbox is as smooth as my Suzuki Bandit or similar. My Norge has less k's than yours at 112,000 but clearly you're on the money.
Offline tris
« Reply #13 on: March 13, 2017, 02:32:22 AM »
I also use the 7100 in the motor
re the tranny/bevel I went and talked to a company that blend the oil you need with a copy of the specs that ITSec put up.
They're response was that "there's nothing special about that its just mineral oil" so just under a litre of their finest went in yesterday
1993 TW125 "POS" - Resting
Offline ITSec
« Reply #14 on: March 13, 2017, 05:21:51 AM »
Thanks for the vote of confidence. As a side-note, to demonstrate my open-mindedness, I should note that my previous DL1000 V-Strom reached 137,000 miles using Shell Rotella 5w40 engine oil. It's my preferred lube for wet clutch water-cooled bikes unless they need a heavier oil.
I have a high regard for Motul - but in my market it's priced unreasonably high and availability is specialty shop only, so it's on my back-up list rather than a #1 choice.
ITSecurity
Offline kirb
« Reply #15 on: March 13, 2017, 06:55:33 AM »
CARC spec is API-GL4
Gearbox is API-GL-5
Anything in that spec range should work.
where you can get the ENI 'AGIP' stuff: http://stelviontx.blogspot.com/2015/11/fluids-change.html
I avoid lucas items because of the quick fix 'anti-leak' and other BS patch products they sell. Personal pref. only.
Offline tris
« Reply #16 on: March 13, 2017, 11:31:21 AM »
Go here https://www.eni.com/en_NL/products-services/automotive-lubricants/transmission-oils/transmission-oils.shtml for specific info on all the Eni Lubricants
Especially go to the very bottom to the " CONVERSION TABLE ROTRA " https://www.eni.com/en_NL/attachments/pdf/conversion-table-rotra-EN.pdf
I've just down loaded the data sheets for the MG "special" oil plus the bog standard ones - very little if any difference IMO - which is not a huge surprise I would think
