Author Topic: Ok Robin moped guru's running issue w/video fixed  (Read 1387 times)
Offline Scott DeRoss
« on: April 12, 2017, 05:32:12 PM »
Ok, it's miss firing. new piston and rings (piston has been triple checked for proper placement) seems to be electrical? carb rebuilt, timing good, maybe points? coil causing this? Would bad engine seals cause this?
Tell me what you think
Tell me how to upload a video from my iPhone Please!!
It was points!!
« Last Edit: April 13, 2017, 09:29:42 PM by Scott DeRoss »
2007 Vintage (Vinnie)
2017 V9 Roamer (Sunny)
1-76 & 3-78 Robins
1975 Honda CT90
1979 Beneli G2 moped
75 850t wifes (Plum Crazy)
79 Honda Ct70 (restored)
MGNOC L-661
Never take life so serious you won't get out of it alive
Offline voncrump
Re: Ok Robin moped guru's running issue w/video
« Reply #1 on: April 12, 2017, 06:16:42 PM »
I can't help you with the video but if you describe the miss then maybe someone could help. Something to check with the little two strokes is for a blocked exhaust. The engine starts but wont rev, it just burbles in a rich fashion. Put your hand near the exhaust outlet and feel for a decent flow. Check that the exhaust note has a bit of a distinct pop to it. Also sometimes the little bit of gas getting through is very hot. These days we are used to four stroke engines so this old problem is not always picked up. When you have experienced this problem often you will recognize it. It happens with small power equipment as well when the spark arrester gets blocked.
Cheers, voncrump
1996 1100 sport
2016 V711
1988  Lario ( long gone )
1982 V50111 (long gone)
« Reply #2 on: April 12, 2017, 06:23:08 PM »
Cheers, voncrump
Did check flow of the exhaust seems to be fine. but, will double check that. It will do like you said and also at times will get higher rpm but popping like a miss fire there as it runs.
1-76 & 3-78 Robins
1975 Honda CT90
MGNOC L-661
Offline voncrump
« Reply #3 on: April 12, 2017, 06:54:56 PM »
It needs to have a good pop pop pop out of the exhaust end. The exhaust blocks slowly and close's the flow gradually.
cheers, voncrump
1996 1100 sport
2016 V711
