A few months ago I spent a good chunk of time cleaning the underside of the engine on my Nevada. Now a few months later, it doesn't look like I've done anything:I don't see any new stains under where it sits in the garage, so I'm wondering what's causing this? My TU250x had the same dirty underside, but I figured that was mostly chain lube.Also, all of my blinkers all have this what looks like a crack on them, but really isn't, white mark on them.I'm assuming if I replace them, the new ones will do the same, so I'm looking for some replacements. Anyone have a suggestion that will look good on the Nevada
Why are the bottoms of my shoes dirty? I just cleaned them...
Pic 1My old Cali always looked like that I assumed it was c££p thrown up by the front wheel. The only solution is to leave it in the garageROFLMAO
As for a dirty crankcase, I minimized it by installing a mudflap on my front fender. In the bargain, this will reduce rear wheel flats by diverting pointy items thrown up by the front tire.
Also, as a former construction estimator, I really dig your user name...
did you know we have a local Guzzi group in the cities? we meet monthly.. are you on the mailing list?
The crankcase dirt is called road grime, nothing to do with engine leaks. The best non mechanical way to deal with it is to clean the bike as well as you can and then douse the whole underside and effected areas of the engine with WD-40 and let it stand for a while. Dont wipe the WD off just ride the bike. The WD leaves a oily film which helps the grime from sticking so it comes off with a wash.I did this with 2 new BMW's I used for 3 month trips in Europe back in the 80's. Bikes went unwashed for 3 months and 20,000 odd klms each. Shipped them back home and a good wash had the cases looking like new againCiao
Are you a fan of Futurama?
