Author Topic: Leaking crankshaft seal  (Read 2278 times)
Offline dxhall
« on: June 17, 2018, 10:04:06 PM »
The Centauro motor I put together this spring runs well, but the lip seal on the crankshaft behind the alternator leaks.  Any thoughts on what I did wrong?
Re: Leaking crankshaft seal
« Reply #1 on: June 17, 2018, 10:19:47 PM »
There's an o-ring too. #7 in this illustration:
https://www.stein-dinse.biz/bilder/auto/breite_800/0002372e.jpg
« Last Edit: June 17, 2018, 10:21:09 PM by Antietam Classic Cycle »
« Reply #2 on: June 17, 2018, 10:22:57 PM »
Why do you think you did something wrong?  I use tape over keyways & threads or anything that might damage it on instillation.
Didn't leak right away did it?
Charlie's got an idea
« Reply #3 on: June 17, 2018, 10:28:12 PM »
There's an O-ring inside the part#8, the sleeve isn't there? Was that replaced and lubed as it went in/on? Also the front seal should be a directional Viton one I believe? If a Nitrile one was substituted it won't of lasted long due to the heat.
« Reply #4 on: June 17, 2018, 10:43:03 PM »
I think the seal rides on #8 and in the pic oring is on the wrong side of it.
Offline dxhall
« Reply #5 on: June 18, 2018, 06:41:08 AM »
I replaced the lip seal, but reused the o ring because it seemed to be ok.  Have there been any reports of poor quality seals?  I don’t like to just replace parts without knowing what caused the failure - that usually leads to repetition of the same mistake.
Offline Mike Tashjian
« Reply #6 on: June 18, 2018, 07:47:07 AM »
O rings are usually deformed to some degree in regular service.  I always replace them with new  when things are apart.  Mike
« Reply #7 on: June 18, 2018, 10:06:06 AM »
I use the Viton(brown) seals if they have them in that size and always new orings.
Offline dxhall
« Reply #8 on: June 18, 2018, 01:53:26 PM »
Not seeing the viton seal on the MG Cycle website.  Do you know who stocks it?
« Reply #9 on: June 18, 2018, 02:13:27 PM »
I have not put one in a Daytona, I was just explaining that I use them if I can get them.
You may want to call MG and see if they can get them.
« Reply #10 on: June 18, 2018, 02:38:00 PM »
"Temporarily out of stock":
http://www.mgcycle.com/index.php?main_page=product_info&products_id=1353
« Reply #11 on: June 18, 2018, 04:54:34 PM »
What size is it? While you may not easily be able to get a directional one from a bearing factor I'm sure you can pick up a standard Viton seal and O-Ring from there. Canberra isn't a big town, somewhere between 400-450,000 souls, but our local suppliers always seem to be able to get me most things I need within a day or so.
« Reply #12 on: June 18, 2018, 05:36:14 PM »
28 x 38 x 7.
http://www.harpermoto.com/17-gasket-ring-28x38x7.html
O-ring:
http://www.harpermoto.com/37-o-ring-17-86x2-62.html
https://www.mcmaster.com/#9262K974
« Last Edit: June 18, 2018, 05:45:32 PM by Antietam Classic Cycle »
