What do you want from a dealer?
Do you know of one, then, that's an established known entity that's not too far from SE PA that'll ship; if that makes sense?Thanks.
Get a ride up there, spend the weekend riding New England have him do the service and ride home.
Jim Hamlin is established and first rate (stellar reputation).Roland (spare parts) is the same, though I don't believe he'll touch late-model electronics. Then again that shouldn't be an issue for basic maintenance.Though I haven't had the III in the fleet long enough to know if there's a way to shut off the maintenance light without a scan tool. I wonder if GuzziDiag would handle that? Not that I'm worried about it.As for shipping, you'd probably save hundreds by renting or borrowing a truck and driving up to get it.Better yet, make it a long weekend, combine it with the first service. Get a ride up there, spend the weekend riding New England have him do the service and ride home.
There's the "wife" factor logistics to consider with that.
Not to get this post too far off track, but my V7 III Special maintenance "wrench" has appeared since about 10,000 miles, and I understand only MG scan will turn it off. But, it is only about 3mm in size and is not distracting, so no problem letting it stay on.
Kev, I just noticed your reply. Do the V7's not have that ability?John Henry
The wrench is a reminder to service the bike as I'm sure you're aware. It comes on at about 6000 miles or whatever the kilo equivalent is. (10,000 Km if I'm not mistaken.) If you change the oil before the wrench shows up, you cannot reset it until it actually comes on. Once it does, you can get into the menu and reset it. It then begins tabulating miles again. I don't know what the service code for your bike is, but once in the menu, you can go to service, enter the code and reset the wrench. I just finished doing this for my 1400 just a little bit ago. You don't have to have scan tool, but you need the code. Disclaimer: I assume the V7 series can do this just like the 1400, Stelvios, Griso's...John Henry
