Author Topic: Wanted Tonti Front Wheel  (Read 935 times)
Offline Don G
« on: May 13, 2019, 01:25:55 PM »
I am building an Ambo-Vert  out of a pile of previously enjoyed parts, am in the mock up stage yet. I am needing a front wheel and hub from a Convert, T, T-3 etc. I am planning on adapting a dual disc brake system using Loop Disc tubes and Tonti lower legs and wheel. I would rather do it this way as the remainder of the front fork will remain loop frame. Thanks ! DonG Oh I guess that I should state that a spoked wheel is what I am after. :thumb:
« Last Edit: May 13, 2019, 01:29:37 PM by Don G »
Offline mtiberio
    • TiberioRacing
Re: Wanted Tonti Front Wheel
« Reply #1 on: May 14, 2019, 09:37:25 AM »
You know you will need bearing carriers that are wider (or a spacer) to make the convert wheel (actually the rotors) fit the loop fork width.
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
Offline Don G
« Reply #2 on: May 14, 2019, 12:05:01 PM »
Indeed I do, need a wheel got every thing else.  Thanks! DonG
« Reply #3 on: May 14, 2019, 10:46:33 PM »
PM'ed you.
