Oil line failure
Topic: Oil line failure (Read 1691 times)
dxhall
Oil line failure
June 19, 2019, 07:11:15 PM »
The cause of my oil leak turned out to be a failed crimp in the Y-shaped hose that goes from the front top center of the engine case to the cylinder heads. It was a major league leak.
Was this failure a fluke, or is replacement of the hose a regular maintenance item? Iām wondering if I should replace the one on the SP III just in case. The LM V is a ā90; the SP III is a ā93, so the hoses are about the same age.
Chuck in Indiana
Re: Oil line failure
Reply #1 on:
June 19, 2019, 07:15:07 PM »
It's a pretty common failure, especially if the previous owner has cheaped out. Get the good one.. teflon lined, stainless braided cover. Not cheap.
bigbikerrick
73 Eldo, 98 V 11 ,12 Ural Gear Up, 76 Convert,
Location: Southeastern corner of Arizona, right next to "Old Mexico, and New Mexico"
Reply #2 on:
June 19, 2019, 07:18:20 PM »
In this application, it pays to spring for the more expensive,better quality lines. The "cheapies" have been known to spring a leak at the most inopportune times.
Rick.
TOMB
Reply #3 on:
June 20, 2019, 05:59:04 AM »
I had the same problem on my convert 1976 to a roundhead I, took the rubber hose assembly off and replaced it with a hard-line oil pipe from an ambassador ,Eldorado haven't had a leak in years and it doesn't rot.
If your bike is for a square head it may not apply however you still can replace it with a hard line pipe I've seen people do it and they basically did it with the brass fittings and then bad to Silver solder to Etc
TOMB
Last Edit: June 20, 2019, 06:00:45 AM by TOMB
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
1976 CONVERT-62000 MILES AND BUILDING
MGNOC # 2723
jwinwi
Reply #4 on:
June 20, 2019, 06:01:58 AM »
This is the one you want:
http://www.mgcycle.com/index.php?main_page=product_info&cPath=68_162&products_id=4361
One of the first things I bought for the V7 Sport was the one made like this for round fin motors. One of very few non original looking parts but I had one of the OEM type hoses spring a leak on my first Guzzi (850T) about 30 years ago - never want to clean up that mess again!
Last Edit: June 20, 2019, 06:03:10 AM by jwinwi
pete mcgee
Gaggle Mentor
Reply #5 on:
June 20, 2019, 05:31:35 PM »
Geez, only 27 or 29 years before failure, guzzi cheaped out.
You have done well padawan.
Is it a service item? Yes in original form, every 10 years or if it shows signs of weeping, a bit like brake lines.
In teflon braided form, on condition.
Buy 2 teflon braided assys and do both bikes, then relax and ride.
I did my mk 3 lemans with teflon braided back in 1995, no issues as yet.
Dont forget the new copper washers for the banjo bolts.
Cheers
Oil line failure
