Author Topic: Bassa Talk - 8K ohms resistance spark plug wires  (Read 1079 times)
Offline normzone
« on: June 29, 2019, 03:07:06 PM »
That's good, right?
I set the meter to Ohms, and mess with the range button until the meter acknowledges that I'm there.
8.08 K ohms both wires.
Valves were fine, just one to two thou over the nominal .005 /.007
Re: Bassa Talk - 8K ohms resistance spark plug wires
« Reply #1 on: June 29, 2019, 03:24:36 PM »
 Yep , now what about the sparking plugs ?
Offline normzone
« Reply #2 on: June 29, 2019, 03:28:48 PM »
They both look RICH, the left slightly more so than the right.
Offline normzone
« Reply #3 on: June 29, 2019, 03:46:16 PM »
Say, did you know that a Jackal dashboard wiring harness is NOT a plug and play candidate for a Bassa?
So much for that idea ... Same amount of connectors, and similar in style, length and configuration, but not the same animal.
Pipe dreams ...
« Reply #4 on: June 29, 2019, 04:03:44 PM »
if all the sensors are ok and everything else is ok Beetle Map Beetle Map Beetle map :thumb:
