Author Topic: 1400 Oil Pressure sending unit  (Read 1911 times)
Offline JohnG770
« on: July 24, 2019, 08:01:30 AM »
Can someone tell me or have a picture of where the oil sending unit is located on a 2014 1400 Tourer? Thanks
Offline kballowe
  • - Kevin the Great -
Re: 1400 Oil Pressure sending unit
« Reply #1 on: July 24, 2019, 08:41:09 AM »
ENGINE OIL PRESSURE SENSOR
Function: it indicates to the instrument panel if there is enough oil pressure (0.5 + / - 0.2 bar (7.25 + / - 2.9 PSI)) in the engine.
Operation / Operating principle: normally closed switch. With oil pressure above 0.5 + / -0.2 bar (7.25 + / - 2.9 PSI), open circuit.
Location on the vehicle: right side of the vehicle, under the oil sump
Pin-out: Voltage 5V
« Last Edit: July 24, 2019, 08:48:08 AM by kballowe »
Offline JohnG770
« Reply #2 on: July 24, 2019, 05:05:59 PM »
Thanks I looked and cannot see it. Do I have to lift the gas tank?  I am getting the flashing red triangle more and more often with the urgent service note. I'm hoping to get to the oil sending unit to check the connection.
Offline DougG
« Reply #3 on: July 24, 2019, 05:41:24 PM »
Hi John,
Look under the bike, I believe that this is what you are looking for:  (sorry for the darkness of the image).  This pic shows the lower front frame member and (hopefully), the oil pressure sensor at the front of the oil sump - just where kballowe said it would be.
Be well,
DougG
Online Bulldog9
« Reply #4 on: July 24, 2019, 06:20:37 PM »
If its the oil pressure switch you should also get the oil can. If not, it may be the demand sensor (throttle position center).
MGNOC#23231
Offline JohnG770
« Reply #5 on: July 24, 2019, 10:00:23 PM »
Thanks guys for the help. If I continue to ride will I cause any damage? I am leaving for Sturgis Friday.
Offline kballowe
« Reply #6 on: July 25, 2019, 07:29:28 AM »
I have this same issue and replaced the oil pressure sending unit and still have the "red triangle and urgent service message"
The bike goes into limp mode with the flashing red triangle.  If you cannot clear this, then you may be stuck in limp mode.
Roll the dice.
Offline JohnG770
« Reply #7 on: July 25, 2019, 08:13:47 AM »
Thanks What happens in limp mode?
Offline DougG
« Reply #8 on: July 25, 2019, 08:19:09 AM »
The bike will only go to a certain speed...slow.  This allows you to get to someplace where you can address the problem without damaging the engine.
Hope this doesn't happen to you... not fun.
Be well,
DougG
Offline Ncdan
« Reply #9 on: July 25, 2019, 09:38:55 AM »
The limp mode is a PITA, however also a blessing if it saves from motor damage. Bottom line is this. If your Guzzi goes in that limp mode it’s not only for the protection of the bikes engine it’s also for your protection. With a ride by wire system the ECU tells the TPS how much fuel to throw to the engine. Pete explained it to me back when I was going through my TPS sensor issues, that were if I was waiting behind a vehicle and when the time tp continue came and I added a little throttle, the TPS keeps the ECU from opening the throttle wide open, thus killing me. Pete has a was of making thinks simple for me to understand. :) mine you this is how my  Limited knowledge  interpreted the cause and effect.
