Author Topic: Torque specs for 1200 Sport brake caliper bolts?  (Read 1348 times)
Offline willowstreetguzziguy
« on: July 27, 2019, 07:28:18 AM »
 Going to put new brake pads, front and rear today on my 1200 sport. Anyone know how much torque lbs.  to apply when reinstalling the brake caliper bolts that hold the calipers on?
2008 Guzzi 1200 Sport
Offline lucian
Re: Torque specs for 1200 Sport brake caliper bolts?
« Reply #1 on: July 27, 2019, 07:41:56 AM »
50nm/ 36ft.lbs      You shouldn't need to remove the calipers to replace pads .
« Reply #2 on: July 27, 2019, 07:43:35 AM »
[/quote
Ok, Do I need to clean out that area after I remove the pads and before I install the new ones with brake cleaner spray?
Offline lucian
« Reply #3 on: July 27, 2019, 07:55:34 AM »
I usually do clean them up and also put a light smear of never seize on the pins than hold the pads.
« Reply #4 on: July 27, 2019, 08:03:28 AM »
Thanks much!
