Author Topic: 8/33 7/33 or 8/37  (Read 1060 times)
8/33 7/33 or 8/37
« on: August 21, 2019, 04:49:39 PM »
The EV had the stock 8/33, which I was OK with, but it made starting off on a hill, especially towing the camper, a bit of a challenge.
I tried a 7/33 set, and that of course helped with the camper, and seat of the pants felt more powerful. But I ended up spending a lot of miles in fifth gear all the time, and noticed a fuel economy drop.
I noticed that MG Cycle had an 8/37 gear set. I figured it was time I learned how to shim a ring and pinion gear set. Now that I have a few hundred miles on it, I can say I really like it. It help when starting off, about like the 7/33 set. And on the highway, I use fourth OR fifth, depending on 'things'. Where with the 7/33 it was always fifth. It feels like a good compromise.
Re: 8/33 7/33 or 8/37
« Reply #1 on: August 21, 2019, 04:52:18 PM »
Wayne, if you have no use for the 7/33 set I'm looking for one for my Cali 1100 that the sidecar is going on if you want to sell it?
« Reply #2 on: August 21, 2019, 05:03:24 PM »
Pete.
It is actually an old worn out set. The ring gear looks perfect, but the pinion is badly pitted and very noisy. I used Redline Shockproof in it to quiet it down a bit while I tried it out.
« Reply #3 on: August 21, 2019, 05:09:33 PM »
Urk! OK then! :grin:
