What RPM range are you operating the engine in . Your engine is a Heron head design , known for producing a nice torque curve , but it still likes to rev . Dusty
Say 2500 to 4500, once above that it smooths out a lot.Gonzo
You're kinda lugging it at the bottom half of that range.Generally speaking I would expect to be in the 4k+ range on that bike. The newer smallblocks tolerate a little lower, but definitely not in the 2's.
Harleys top out at 5k rpms. I think that's the answer.
The point I want to raise here is that the power delivery on the Breva is very different to the other twins. I find it so much more impulsive, as if the flywheel were much smaller. I can feel every power impulse as I accelerate. The compression ratio is comparable with the others, and the state of tune is similar. The torque reaction when I blip the throttle is strong, so I assume the flywheel is normal size.So, am I deceiving myself? Or does the SB have something special?Gonzo
I've owned Sportsters. Riding around at 1800-2000 is normal.
I guess things have changed in terms of gearing since you owned a Sportster, cause THAT'S LUGGING IT TOO.For rubbermount sportys (2004+) and probably most EVO solidmounts (through 2003) you really should be above 3k most of the time.BT's can run as low as you're saying....
???!!!???V7 III Bore 80 mm, stroke 74 mm883 Bore 76.2 mm, stroke 96.82 mm
Guzzis and Ducatis = Over Square, bore diameter larger than stroke length.Harleys = Under Square, bore diameter smaller than stroke length.Big personality difference in the two layouts.
