First question, is the headlight on?For some reason best known to Guzzi the headlight relay also feeds the reference voltage to the alternator and rotor. So if that fails, then the alternator won't charge.There are two fuses which can cause this, a 15 Amp one which supplies the relay coil, fuse B in the auxiliary fuses, and a 20 Amp one which supplies the headlight. If either blows, you get no charging.Find the light logic relay which is up front, under the fairing, left hand side. Sort of under the dash. Bridge terminals 87 and 30, and see if you get the headlight and charging.
Looks like I found it. I'm a dumb ass, the top 2 prong plug on the back of the alternator was not connected. I'll update when I get everything back together. Thanks for help though. I'm still learning about these bikes. They're a world different than my old 66 Beemer.
