Well, I took apart and cleaned the battery terminals, the frame ground lug, the positive cable to the solenoid, and the "trigger" wire for the solenoid, and no change at all. As I took the connectors apart, I noted that they were already pretty clean, but they're really bright and tight now.So out with the voltmeter. When I turn on the key and press the starter button, I can hear the little faint "click" of a cube relay, which holds for three or four seconds before clicking "off" ... but there is ZERO voltage at the trigger wire for the solenoid - the needle doesn't even twitch. So something is broken, or something is signalling the relay to NOT energize that wire. The neutral light is "on", I've cycled it in and out of gear, and on this bike, you don't need to have the sidestand up or the clutch pulled in to start it.What's the next evolution?Lannis
Any chance you dropped the bike, I'm thinking of the tip-over relay, it gave me trouble on my Griso.
Yeah, but it was a long time ago in Nova Scotia.
So now I'm looking for a circuit that is common to the starter solenoid feed and the glove box door, possibly a fuse. Back to the wiring diagram.
This morning I'm off to the woods with a chain saw to finish clearing a walking trail. Supposed to rain this afternoon, so back out in the shop then ....Lannis
Came home, replaced the blown 15A with a 20A (I'm coming to get Kiwi Roy if my wiring melts, although I've seen him elbow deep in his EV's wiring and he knows what he's about), and replaced the other fuses just for drill, turned on the ignition, checked to see if the glove box opened ... it DID ... punched the starter and .... NOTHING. Nothing but much cursing and gnashing of teeth until I realized that I hadn't connected the solenoid trigger back up, getting in a hurry and all, connected it back and it starts like a good 'un.
Yea , Kiwi is right on that fuse. The wiring will handle 20 amps and sill pop the fuse if there is an issue.Since it popped the 15, you may have a sticking solenoid, or startus interuptus, creeping in, that prevents the solenoid from moving fast enough. That longer duration load pops the fuse.
All interesting stuff but I'm curious how a glove box works in the first place and how it stops working due to a fuse?
I don't believe the factory knows how much current the solenoid drawsFor one thing it only draws 35-40 Amps for about 20 milliseconds normally, that's too fast for a normal meter to register.
You MIGHT think that an electrical design engineer responsible for designing and testing solenoids could have invested a few hours pay in a peak-hold meter, or maybe a scope? Oops, I forgot - GUZZI CONTENT!
Or even a proper schematic of the starter.
I have a box of Cat starter buttons made for current, bubber heavy duty switch made to step on or push.I'll send you one, mount it on the dash. Run heavy fused wire to it then to solenoid from batt. to hell w/rest of sys, your bike goes all the time. I installed a few over the years on BMW's also.
I suppose it's part of the "character" of owning a Guzzi, to have a substandard starting circuit that hasn't been fixed in 30 years, and components that aren't up to the job.Besides carrying spare fuses, at the next impending failure I'll take pyoungblood's suggestion of a heavier ground cable, although the one on it works when everything's clean and optimal, and prepare to make the "startus interruptus" mod.On my '75 electric start Norton, I've fixed so that it works every time by simply running a clean heavy ground cable directly from the battery to the starter. It's no longer an "electric assist" but a real electric starter; everything else is stock and it works like a champ. Norton probably saved 43p per bike with the OEM cable and for that, they gained an eternal reputation for not knowing what they were doing ...Lannis
Not sure if I’m reading this correctlyDid a ten year old bike blow a fuse and create havoc on the net?
Glad it’s fixed
I don't know anything about a Norton electric start but it seems to be similar to a lot of Japanese with a permanently engaged starter and simple clutchUnlike the Bosch and Valeo Guzzi starters that have to move a heavy gear into mesh with the ring gear, I think it takes a minimum of about 30 Amps through the solenoid coils to do that.
The fuse pops, when the starter solenoid sticks. That may be by design, and may actually be a GOOD thing. Even if it is frustrating.
It's a strange little hexagonal spacer, 13mm AF. It has a 4mm threaded bit on the inner side that the earth straps bolt under to the gearbox and then it's got another 4mm thread on the outer end that the starter motor cover screw goes into. Be careful not to over tighten it or it will strip!
