I applied rubber grease to a suitable sized O-ring that went between the case and shift arm...........
The transmission box should be open to atmosphere. No internal pressure development.When you did the restoration, did you replace the shift shaft o-ring inside the rear cover?The 5- speeds have a shift shaft o-ring seal. The 4-speeds do not. When asked, I modify the 4-speed shift housing to accept the same o-ring as the 5-speed.If you want to get anal about the drip, you could always run a few cc's shy of full.Patrick HayesFremont CA
Considering trying out a slightly thicker oil as well.
OK, so what oil are you currently using? Some brands foam up much worse than others. That's a good thing for the foam to push some lubricant to hidden places, but a bad thing if there are any vents that could allow a weep.Patrick HayesFremont CA
Shift Shaft, Weep....Try saying that five times real fast..Just having fun.Earl
