Author Topic: 1974 Eldo (was chrome bores)  (Read 3120 times)
Offline SED
« on: June 19, 2020, 10:55:12 AM »
I'm going to look at this Eldorado this weekend and want to know if there is a way to distinguish chrome bores from the outside.
My perception is that there are 3 choices - chrome, cast iron and nicasil.  Any distinguishing marks?
The other question is if it is a police spec bike.  I'll take pictures and ask more questions then.
Thank you!
« Last Edit: June 20, 2020, 10:11:49 PM by SED »
1983 LeMans III
1981 Monza
1947 Ariel Red Hunter
1939 Ariel Red Hunter
1937 Guzzi GTV
Offline Turin
Re: How to tell chrome bores Eldo?
« Reply #1 on: June 19, 2020, 11:02:15 AM »
If the barrels were replaced with a Gilardoni kit, then you will see the name stamped into the bottom off the cylinder at the bottom fin.
I don't know of any other external cues.
1986 Sidlow Guzzi
1996 Triumph Daytona 900
Offline SED
« Reply #2 on: June 19, 2020, 11:05:42 AM »
Thank you Turin!
1983 LeMans III
1981 Monza
1937 Guzzi GTV
Offline TOMB
« Reply #3 on: June 19, 2020, 11:12:11 AM »
Buy the bike, there are plenty of people that would buy it in a heart beat.
Disk Brake Eldo,  very desirable and worth the investment if you decide to take it on .
A true Police  Bike should have the ignition switch on the left side under the seat, and usually no tool box on the left side as the ignition switch takes up that space. but there are variations due to Police dept. requirements and after all these years what has been changed by previous owners.
Hopefully some one here can help with the Serial number ranges
Others will chime in .
TOMB
« Last Edit: June 19, 2020, 11:18:49 AM by TOMB »
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
Online Cam3512
« Reply #4 on: June 19, 2020, 11:18:29 AM »
That does appear to be a police bike.  Most likely a '74.  Round tail light or rectangular?
Offline TOMB
« Reply #5 on: June 19, 2020, 11:22:39 AM »
Just noticed that there is a setup ball attachments for a sidecar dont  overlook any abnormal ware (forks out of alignment etc.)
Please keep us informed.
TOMB
TOMB
CENTRAL CONNECTICUT
1980 CX100 50 MILES
MGNOC # 2723
« Reply #6 on: June 19, 2020, 11:23:24 AM »
The Gilardoni name doesn't always appear on new Nikasil plated cylinder sets. I suspect some of the casting was outsourced to another foundry.
Easiest way to determine what you have:
1. remove a spark plug
2. make sure the piston is down from TDC
3. Insert a "pencil magnet" in through the plug hole and touch the cylinder wall.
Zero magnetic attraction = chrome, very slight = Nikasil, strong = iron liners.
If the seller isn't okay with you doing this simple, non-invasive test, then it might be best to walk away unless the price is very reasonable.
« Last Edit: June 19, 2020, 11:27:28 AM by Antietam Classic Cycle »
Offline SED
« Reply #7 on: June 19, 2020, 11:25:58 AM »
Round taillight.
Thanks guys.  I was asked to help sell it, so just gathering info now.
Am I correct that all Eldos had chrome bores originally?  And that they could have been replaced with either cast iron or nicasil?
Grazie!
1983 LeMans III
1981 Monza
1937 Guzzi GTV
« Reply #8 on: June 19, 2020, 11:29:42 AM »
Round taillight.
Grazie!
Yes, all chrome bores originally. Some that saw use with police depts. may have (big bore) iron liners installed already, others might have been done later. Liners were the "fix" up until replating became common in the '90s.
Offline SED
« Reply #9 on: June 19, 2020, 11:33:27 AM »
Thank you Charlie!
Any external clues to "big bore" replacements?
1983 LeMans III
1981 Monza
1937 Guzzi GTV
Offline Turin
« Reply #10 on: June 19, 2020, 11:45:37 AM »
Nope. The Gilardoni stamping is the only external clue I know of. The only sure fire way of knowing is the magnet test listed above, and that won't tell you about the bore.
1986 Sidlow Guzzi
jwinwi
« Reply #11 on: June 19, 2020, 01:13:42 PM »
So there were Civilain Eldos with 2 separate gauges and footpegs and 'Police' versions with footboards, a single aluminum speedometer housing and higher handlebars. But weren't a 16" rear wheel and the left side ignition switch features of bikes actually used by LEOs?
« Reply #12 on: June 19, 2020, 01:50:24 PM »
AFAIK, the 16" rear wheel was used by the CHP only.
A siren mount or the ground off remnants of one are a dead giveaway of it being a "real" police Loop. But, not all PDs used friction sirens, so just because it doesn't use one doesn't meant it was used by a PD.
Online Cam3512
« Reply #13 on: June 20, 2020, 07:55:43 AM »
And not all police model bikes were actually in service with a PD.  Some were sold directly to civilians after removing the siren bracket.
Offline JC85
« Reply #14 on: June 20, 2020, 04:45:49 PM »
Some police models were also imported and sold directly to the civilian market. Mine is an example of that. True police model with all of the upgraded features (aluminum dash, oversized, locking kickstand, steering stabilizer, left side ignition, etc,) but never saw police service.
'74 Eldo Police Model
'07 CalVin
Offline Yeahoo Whoyah
« Reply #15 on: June 20, 2020, 04:49:33 PM »
SED: Anxiously waiting for photos, questions, and....did you buy it!
Greg Tillitson
El Dorado Hills Calif.
Offline SED
Re: 1974 Eldo (was chrome bores)
« Reply #16 on: June 20, 2020, 10:27:46 PM »
Looks like an original paint Police Eldo.  Even the paniers were pinstriped the same as the fenders and tank.  vin tag says Apr. 1974.  Gilardoni cylinders.
It had a very long side stand and steering damper.  It also had a skid plate of sorts, bolted under the sump.  Didn't find anything that looked like a siren mount, but it does have sidecar brackets.  It looks like a great, honest bike that needs some TLC.  There are more pictures but these show most of it.
Any idea what it is worth?
Thank you!
Shawn
1983 LeMans III
1981 Monza
1937 Guzzi GTV
Offline siabeid
« Reply #17 on: June 21, 2020, 12:17:19 AM »
Shawn, Is this the  bike from Dirk's estate? I paid 5k for mine, which was a heck of a deal for it's condition. I would think that this one  is worth at least that in a quick sale and probably quite a bit more. If I remember correctly, Dirk's  bike was in pretty good running condition.
« Reply #18 on: June 21, 2020, 07:14:53 AM »
Is it for sale? If yes send me a pm.
Offline JC85
« Reply #19 on: June 21, 2020, 04:29:46 PM »
Thank you!
Shawn
Yep. With that dash, the Kickstand, and the steering damper, definitely a Police Model. And a 74, to boot! That's the apex of the loop frames, right there. If you're able to acquire this thing, you'll absolutely love it. As far as what it's worth, I can't help on that. I've never been interested in selling mine, so I have no real idea.  :laugh:
'07 CalVin
« Reply #20 on: June 22, 2020, 04:51:28 PM »
When in doubt, change the oil.  :thumb:
« Reply #21 on: June 22, 2020, 05:11:39 PM »
IMO it would be a minimum of $5000.  Doesn't the seller have a price in mind?
Greg Tillitson
Online Cam3512
« Reply #22 on: June 22, 2020, 05:15:52 PM »
Agreed.  Minimum $5K all day long.
Offline Denis
« Reply #23 on: June 23, 2020, 10:16:05 AM »
That is a damn nice Eldorado.
Offline SED
« Reply #24 on: June 23, 2020, 11:12:54 AM »
Thanks for the interest and estimates guys.  I was thinking $5000 min too, but don't have much expertise.
The bike will be sold and she wants it to go to a good home.  She has fond memories of times on the Eldo.  She is well connected socially and very level headed, but doesn't have internet.  I've passed along the info so it's up to her now.  I'll let you know when I know more.
Thank you!
Shawn
1983 LeMans III
1981 Monza
1937 Guzzi GTV
« Reply #25 on: June 24, 2020, 03:15:24 PM »
SED:  Where is the Eldorado located?  I've read this post several times but didn't see it mentioned.
Greg Tillitson
Offline SED
« Reply #26 on: June 24, 2020, 07:06:14 PM »
I avoided mentioning because the owner hadn't told me what she wanted until today.  The Eldo located in north of Seattle.  She's asking $6000 and hoping it sells locally.  She knows I've asked for your (WG) knowledge and opinions and that a couple of you have expressed interest.  If it doesn't I'm willing to ride and report for a distant buyer, but we need to wait until she's ready to do that.  She is fond of the bike and I think would like to meet the buyer.
1983 LeMans III
1981 Monza
1937 Guzzi GTV
« Reply #27 on: June 24, 2020, 07:07:26 PM »
It currently runs? or needs some work to get it running?
Offline SED
« Reply #28 on: June 24, 2020, 11:58:07 PM »
It's a runner - battery had to be charged.
1983 LeMans III
1981 Monza
1937 Guzzi GTV
