Maybe LM I?Give Harper's a jingle.
What bars- original swan neck, plain tommaselli low clip ons, riser/z-style clip ons, ?My V7 Sport has a two cable Tommaselli Daytona 2C throttle and plain Tommaselli clips-ons. I made mine from spare too-long cables on hand. Not very difficult, especially if your existing cable already has at least one soldered end instead of crimped or molded ends. remove it to reuse.
OK, how about a set for the Tommaselli that are 44" overall length, 39 1/2" sheath? They are new but probably too short.The cable set I have for the stock V7 Sport measure overall length at 46".Now that I look more closely this is probably a stock SP/CX cable for use with the stock plastic throttle/control of that model. Sorry.John
On my Sport i used the short cables from a T3 with the short handlebars.Tomisseli throttle assembly. I also had the swan neck bars .The cables mentioned above were the correct lengthen for my application.Ill update this thread with the part # in a few minutes.Here you go,These numbers are from the period 1976 ish factory parts book and may have been updated over the years. These cables ARE NOT for the Police style barsAt the same time Barnett also made cables for the T3.17117500 Twist grip cable NEED 217122550 choke cable RH17134050 choke cable LH/I used individual lift chokes on each carb. Hope this info helps.TOMB
