I tackled taking both wheels off the Stelvio today and had new tires installed. Should be able to ride around here by April if the easy winter continues. I used Leafman's excellently tutorial for the front wheel and it was very helpful. I think I've got it all bolted back together properly but I'll ask for some guidance on one rather important aspect: the axle on the left side is recessed into the fork clamp by about an eighth of an inch. Is this the way it's supposed to be? I didn't notice it to be that way when I was taking it apart. Thanks all. Can't seem to figure out how to attach a picture.
Hi kidneb, when you say "just copy and paste" old dudes like me think of "paste" as a white substance in a jar that stings if you get it in your eyes......Um yeah, right!! Anyway, can you tell me how to "just copy and paste" ? And please don't presume that I understand any "shortcut" terminology that you might use. Thank you.
Thanks, Yo.I should have included some pics. I'll try to add some this weekend.The rider's left side axle does recess. The pinch bolts holding that side allows for adjustment of the fork tubes to not bind in the fork leg shock assembly when compressed.Step 8 of my old post describes loosening the rider's left pinch bolts and bouncing the front end and then tightening those pinch bolts along with all others. This procedure will float the lower left pinch casting to properly locate on the axle so as to not create a bind of the leg under compression. The exact relationship of the lower pinch clamp on the recessed axle will depend upon the specific bike and the alignment of its fork legs. Don't overtighten the small pinch bolts. Only 10NM.
