Author Topic: Crimping Spark Wire Terminal at Coill  (Read 1329 times)
Offline SmithSwede
  • I don't want a pickle
« on: August 03, 2020, 12:58:58 PM »
What is the correct way to fit or crimp the new coil side terminal onto a new spark plug wire on a V7 Stone small block?  I’m assuming I need a crimping tool, but what kind?  Anyone have a picture of what the finished product should look like?   Should I solder this?  Epoxy?  Tips?
The terminal looks this.  I’ve confirmed that the small end on the left with the little circlip snaps into some fitting inside the coil.
Thanks.
« Last Edit: August 03, 2020, 01:01:07 PM by SmithSwede »
Accentuate the positive;
Eliminate the negative;
Latch on to the affirmative;
Re: Crimping Spark Wire Terminal at Coill
« Reply #1 on: August 03, 2020, 01:33:15 PM »
« Last Edit: August 04, 2020, 12:16:22 AM by Tom H »
« Reply #2 on: August 03, 2020, 11:03:31 PM »
Thanks for posting the link, I need to make some proper terminal connections on HT leads, just what I was looking for!
LesP
« Reply #3 on: August 04, 2020, 02:54:38 AM »
The crimp tool would be best but for a one of job I just made a very quick press tool.
I cut the outer back far enough to allow the copper core to be long enough to do a return / horse shoe inside the terminal body and flattened to get a good compression and hopefully good conductance.
This is a distributor bike so copper core was my first choice, with electronic ignition bikes some folk prefer carbon core... There are a few choices as far as core material.
« Last Edit: August 04, 2020, 02:57:44 AM by LesP »
Offline s1120
« Reply #4 on: August 04, 2020, 07:13:51 AM »
Concept is pretty much the same that I use with a set I got from Accell a few decades ago.. Just two plates in there case. Simple and cant break.  Sadly I could not find them when I did my last set..
Paul B
« Reply #5 on: August 04, 2020, 08:34:01 AM »
I bought this one last year, and although it's made of some sort of plastic, it has worked very well.
https://tinyurl.com/accel-plug-wire-crimper
« Reply #6 on: August 04, 2020, 09:22:01 AM »
I like that one!
« Reply #7 on: August 04, 2020, 10:57:35 AM »
That little one looks cool. But how wide is it? The OP needs to crimp two places it looks like?
« Reply #8 on: August 04, 2020, 11:08:03 AM »
Over 1" wide. SmithSwede's terminal only gets crimped one place.
Not very good reviews on Amazon - lots of "broke on the first use" comments - but I've used mine to crimp over a dozen terminals and it's worked perfectly well.
« Last Edit: August 04, 2020, 11:11:51 AM by Antietam Classic Cycle »
« Reply #9 on: August 04, 2020, 11:17:39 AM »
Got it, looked like two places and you bend the wire for the curve. It's just like a normal 90 degree connector.
Thank you!
