Did he have any explanation for the failure?
So, just to follow up this experience. If you out riding and your rear wheel bearing goes out, if at all possible stop immediately! I don’t know how Guzzi’s are designed, but a Victory V92c does extensive damage when the bearing goes out. I’m going to have to source a one new axle spacer, hub spacer, and an entire rear wheel. I’m also going to need new rear pads, as the rotor ate into the pad all the way to the metal. The bearing got utterly destroyed. The wheel had a broken spoke. I don’t know it that contributed to it or not. Either way, a rear bearing failing is expensive if you ride on it! As I have found out.
