Greetings,The V85 TT "Use+Maintnenace Book" (page 146) states the following:"The full performance of the vehicle is only available after the service at the end of the running in period."I am trying to gain some understanding of what this exactly means. Is this basically a message to me -- as the rider -- to continue to ride the bike rather gently until the mileage and recommended initial service is completed? Is there -- conversely -- a trigger-point programmed into the ECM to adjust fueling/timing etc. once the odometer passes the break-in mileage? Or.....is this some sort of map download/install which only a dealer can do -- in which case I may need to ensure that the dealer service department knows about this and gets it done.Is there some means by which I myself can *know* that my bike is operating with its' "full performance?"Thanks for any clarity.
Hi guys, been awhile since I have posted, been distracted with an Italian dual purpose bike i purchased with 1.4 miles on the odometer.The speedo on the dash will record your performance of each ride. As I scrolled thru the various functions I noticed the highest speed recorded was 72MPH!When I asked the seller why he had taken the brand new bike 72 mph (close to wide open throttle), he informed me it was like that when he purchased the bike.The service manager told him if the engine is going to detonate they would rather have it done prior to the customer picking the bike up. He added that by running the engine with a full load it will help the compression rings seal better. Being a bit skeptical I did a little research and came across a study which compared two identical engines. One was broken in according to manufacture specs (very gentle), and and one which was run like they stolen. After the "break in period", both engines were disassembled for comparison. Neither engine showed any appreciable difference in wear. In fact the engine run the hardest showed less carbon build up in the ring grooves indicating they were actually sealing better than the mild break in.These new engines and materials aren't anything like the engines of old.
If recent forum history is any proof. It doesn't matter on the break-in procedure that's chosen. What matters is if the owner riding his bike is extracting the rpms out of the engine. Higher rpms is always better for the Moto Guzzi vee.
