What Yuasa Battery for an 850-T3?
Topic: What Yuasa Battery for an 850-T3? (Read 2074 times)
Kane
Hatchling
July 07, 2021, 01:36:10 PM »
The 1978 850-T3 needs a new battery. I have fast access to Yuasa AGM batteries. Would like to know what model Yuasa battery folks are running in these bikes and how well they work.
Thank you!
2001 V11 Sport
1978 850-T3
2009 Ducati 1100 Hypermotard
cliffrod
AC Button II
Re: What Yuasa Battery for an 850-T3?
Reply #1 on:
July 07, 2021, 02:35:12 PM »
The last proper regular lead/acid Yuasa battery I got for my V7 Sport (Tonti frame but not sure if same battery is used for the 850 T3) is a Yuasa Y50 N18L-A. Long, skinny & not too tall. good fit, no problems for several years & was very happy with it. Maybe that number will help you with a cross reference.
1973 V7 Sport "Now THAT'S a motorcycle!"- Master Sculptor Giuliano Cecchinelli
Gliderjohn
Reply #2 on:
July 07, 2021, 02:43:41 PM »
I run the common lawn and garden battery that you can buy about anywhere for $30-$40.
East Mountains, NM
guzzisteve
"Just Ride It"
Reply #3 on:
July 07, 2021, 02:56:17 PM »
Well, I looked it up, something YOU the poster could have done
GYZ32HL or YD30L-BS
Most likely $300 knowing Yuasa Well, you got the recommended 32AH Yuasa #'s let's see if you are cheap!
This one isn't too far off my idea
https://www.titancustoms.com/gyzfaagmmaba1.html
Last Edit: July 07, 2021, 02:59:38 PM by guzzisteve
Antietam Classic Cycle
Happily stuck in the past.
Reply #4 on:
July 07, 2021, 03:33:49 PM »
I use a Deka ETX30L, this is Yuasa's equivalent:
https://www.yuasabatteries.com/battery/yix30l/
"Only" $182 on Amazon...
Last Edit: July 07, 2021, 04:01:35 PM by Antietam Classic Cycle
Kane
Hatchling
Reply #5 on:
July 07, 2021, 04:20:11 PM »
Thanks for the responses and help. The shop carries YT12B-BS, YTX14-BS, and YTX15-BS. I guess those won't crank enough as they are not like the 30a you guys are showing. More amps, more money it seems.
Last Edit: July 07, 2021, 11:15:54 PM by Kane
2001 V11 Sport
1978 850-T3
moto-uno
Reply #6 on:
July 07, 2021, 05:59:45 PM »
If you are using one of the later starters it may be plenty , they are way more efficient than the original Bosch starters
. Peter
Guzzistajohn
Reply #7 on:
July 07, 2021, 06:52:54 PM »
I ran a cheapo Wally-World lawn tractor unit for many years like my flat-lander friend GJ and switched to ODYSSEY. They cost more, but
imagehosting site
take up less space, when they're hot, they're really hot. But when they're dead, they're just as dead as a Wally world POS. It's splitting hairs really. it would be more Guzzi-esque to go cheap-ass
Last Edit: July 07, 2021, 06:53:30 PM by Guzzistajohn
Reply #8 on:
July 07, 2021, 06:58:29 PM »
https://www.batterymart.com/SEARCH.html?q=etx30l
weevee
Gosling
Reply #9 on:
July 08, 2021, 02:03:05 AM »
Just FYI.. The relatively tiny AGM Yuasa battery from my Honda VFR (..only 8.5ah) has been doing a fine job turning-over & starting my big-block Daytona engine for the last three months, and it's been charging (..and holding its charge) without an issue. It was fitted as a temporary measure because the bike's OEM battery died whilst it was standing idle over the winter, but I only got around to acquiring a new (20ah) battery for it yesterday. The tiny Yuasa battery is still fighting-fit, and this morning is showing over 13v at its terminals after trickle-charging on the bench last night.
Last Edit: July 08, 2021, 02:04:35 AM by weevee
