Author Topic: How Cast Iron Pans Are Made  (Read 5572 times)
Online Perazzimx14
Re: How Cast Iron Pans Are Made
« Reply #30 on: August 12, 2021, 12:45:35 PM »
     It's great hearing professional and varied insights to add to my cooking bag of tricks,  :bow: :thumb:
     I think Mayor nailed part of the problem for me, is a lack of good ventilation inside; I cook on a Jennair downdraft poorly vented cooktop; so I am probably cooking at too low a heat, trying to keep the smoke and fumes to a minimum.
      AJ that's an interesting flip side to the opinion of river sand; years ago, I worked in a precast plant, the owner was extremely "frugal" and started buying cheaper dredged up river sand instead of the sharp concrete sand, the Italians hated it, they said it made the concrete like mud.
     I thank everyone for their replies, I'll be trying some of those ideas out, the next time bad weather forces me off the BBQ into the house.
Cheap Coleman white gas gas stoves or a propane turkey fryer burner work a treat. Cook outside and the smell stays outside. Between the garage and driveway that is where the lions share of the cooking is done. Especially when frying, searing, cooking fish or other foods that smell tends to  linger around for days.
2017 Road Glide Special
2020 Kawasaki KLX300SM
Offline 80CX100
« Reply #31 on: August 12, 2021, 12:47:31 PM »
Oh yeah, and read Cliffrod's post twice before you begin!  :boozing: :boozing:
      I learned quite some time ago, when he posts on cooking, I read it at least ten times ,lol  :bow: :thumb:
      I used to think that I could put on pretty fine spreads for large groups, but after reading some of your posts Mayor, you're in another league yourself  :bow:  :thumb:
« Last Edit: August 13, 2021, 12:22:11 AM by 80CX100 »
2008 California Vintage
2003 V11 Lemans
1979 G5 & 1980 Lemans CX100
Offline 80CX100
« Reply #32 on: August 12, 2021, 12:51:31 PM »
       I've watched some of your amazing Coleman meals and I've wanted to try it, but whenever I reach for the stove, the pump gets fussy, can't find the fuel or the funnel etc, but I might up my game for the CI
      tks
2003 V11 Lemans
Offline sib
« Reply #33 on: August 12, 2021, 01:09:33 PM »
My pan-cooking method for stakes is to heat the (Griswold) skillet on a gas stovetop on high het for several minutes, until the residual glaze on the pan surface begins to smoke.  Put salt and pepper on one side of the steak and put that side on the skillet.  Do not turn down the flame.  Use no butter or oil.  After 3-5 minutes, depending on the thickness of the steak and your doneness preferences, put salt and pepper on the unseasoned (top) side and flip the steak.  After 3-4 more minutes, remove the steak, then butter it f you want.  The dry steak will not stick to the skillet when it is seared properly by the HOT skillet.  Enjoy your steaks.
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
« Reply #34 on: August 13, 2021, 05:33:31 AM »
this is the way....
« Reply #35 on: August 13, 2021, 10:17:59 AM »
I have an assortment of cast iron cookware and have prepared full Thanksgiving Dinners including dessert out in the woods on cast iron.
I even carried a small skillet with me all the time in my saddlebags, but lost track of it on a trip.
Online TN Mark
« Reply #36 on: August 13, 2021, 10:40:08 AM »
There was previous thread on cast iron cookware.  I thought I'd post this with a vid on they're made.
https://kottke.org/21/08/how-cast-iron-pans-are-made?utm_source=GetTheElevatordotcom
Tom,
     You start some of the most educational and informative threads on the forum. Thank you sir! And yes, the wide range of knowledge and talent on this forum is wonderful.
Online Perazzimx14
« Reply #37 on: August 13, 2021, 11:10:04 AM »
      tks
If the pump gets fussy or won't hold pressure break out the WD-40 or PB blaster and give the pump a shot in the "oil" hole. Like Billy D. Williams and Colt 45.......Works Every time!
« Reply #38 on: August 13, 2021, 06:54:37 PM »
Tom,
Thanks.  Trying to help the forum.   🙆‍♂️  :grin:
