Author Topic: Calvin Mileage Dropoff and Fuel Light Problem (New Questions)  (Read 2130 times)
Offline JC85
« on: August 25, 2021, 04:11:17 PM »
So the mileage on my 2007 Calvin has recently taken a dump. Over the last few weeks, it's gone from 40+mpg to 35mpg. It happened suddenly on a weekend trip up to Lawrence to see some friends. I got about 40 on the way there, then got 35 on the way back. At first I thought maybe some crappy gas. But after filling up here at home, it's still at around 35.
The second issue is that the low fuel warning light is coming on at about 100-110 miles. Now, I've been told and am aware that the low fuel light on a Calvin comes on when the tank still has1.5 gallons of fuel in it. Still, even with the bad mileage I'm getting, it came on when I'd only used 3.112 gallons, today.  So if it is coming on with 1.5 left, then that's only about 4.4 gallons, total, which is nearly a full gallon less than Guzzi's stated 5.5 gallon capacity. Anyone else had these issues or have any tips?
P.S. I run nothing but premium, and nothing about my riding habits or the amount of highway vs in town miles has changed, recently.
Thanks in advance.
« Last Edit: August 25, 2021, 09:36:19 PM by JC85 »
'74 Eldo Police Model
'07 CalVin
Re: Calvin Mileage Dropoff and Fuel Light Problem
« Reply #1 on: August 25, 2021, 04:46:14 PM »
Just so you know WE didn't make the thing. Maybe call the 800# and tell the mfg. but look at what you haven't looked at yet. Have you actually cleaned the TB's and removed the air bleed screw and cleaned them? I do mine every 10K mi. How about setting the TPS? How about the air filter or fuel filter? When was the last time anything got attention? I know how all the cheap suspender snappers are, do nothing and expect things to run forever.
The CalVin should be getting 50 mpg or it's not tuned correctly. AND I'm not trying to give you any grief about it. It's your bike.
« Last Edit: August 25, 2021, 05:01:20 PM by guzzisteve »
Offline JC85
« Reply #2 on: August 25, 2021, 05:24:39 PM »
It never ceases to amaze me how some people on this board get nasty when someone asks for advice and input. As if that wasn't one of the purposes of the board, in the first place. I'm already planning on checking a few things. But I have limited mechanical knowledge, especially with modern bikes that have fuel injection and computers, so I was simply wondering if anyone had any specific experience with these issues and might have some suggestions.
Next!
« Last Edit: August 25, 2021, 05:26:57 PM by JC85 »
'07 CalVin
Offline Guzzidad
« Reply #3 on: August 25, 2021, 05:48:51 PM »
   I don't think Steve was getting snarky at all. He gave you some very good tips to address your issue, free. These are all things even someone with limited mechanical ability can accomplish.
Offline lazlokovacs
« Reply #4 on: August 25, 2021, 06:00:43 PM »
The CalVin is dual plugged.
It could be that one or more of your plugs isn't firing. The bike wouldn't run much differently, but the burn could be much less efficient if say one cylinder is only firing one plug.
Do you have Guzzidaig?
I would connect it and try the spark plug firing test and make sure you're getting a fat spark at all 4 plugs.
Are there any other symptoms? Any oil leaks? Even slight ones?
Please keep me updated, I've got over 100,000 miles on Calvins and had them apart and back together many times. We'll get you sorted.
Offline lazlokovacs
« Reply #5 on: August 25, 2021, 06:05:16 PM »
I have a lot of respect for GuzziSteve, but I don't feel confident that any of these factors would lead to a sudden drop in mileage as described.
I could be wrong but...
Offline JC85
« Reply #6 on: August 25, 2021, 06:06:21 PM »
Ok. Steve, I do apologize for getting a bit testy. The tone of your message struck me the wrong way. That being said, thank you for your suggestions. Now, I'd like you to know a few things about me. I'm a relatively younger guy who, though I grew up with them, has only been riding and working on Guzzis for a few years, now. I genuinely enjoy working on and maintaining my own bikes, and am happy to do so, but as I said, I have limited knowledge, so I'm learning as I go. I'm not at all someone who just let's things go and gets upset, when they don't run right. It took me several years of hard work and research to get my dad's old Eldo sorted and gain the knowledge to do so, and this Calvin (which I just bought in October of last year) is my first modern bike. So now I'm sort of back to being lost, when it comes to issues and fixes. That's why this board and the collective knowledge of the people on it are such an invaluable resource for me, and why I come here for advice.
Anyways, no hard feelings on my end, and I hope there aren't any on yours.
« Last Edit: August 25, 2021, 06:12:18 PM by JC85 »
'07 CalVin
Offline JC85
« Reply #7 on: August 25, 2021, 06:09:33 PM »
Thanks for the tip. My first thought was to check plugs and air filter. I'm going to pull and test the plugs, this weekend, and check the air filter, while I'm at it. No other symptoms that I can tell. Not a drop of oil on my shop floor, where I park it, power and torque seem to be as good as ever, no added engine vibration, etc.
I don't have Guzzidiag. Anything that can be wrenched on, I can handle, as long as I know or can find out how to do it. Vehicle computer issues are totally foreign to me.
« Last Edit: August 25, 2021, 06:11:30 PM by JC85 »
'07 CalVin
« Reply #8 on: August 25, 2021, 06:19:06 PM »
The low fuel light is probably a thermistor or perhaps a float switch, Neither of these will suddenly move and operate at a different level.
Is the fuel pump making more racket all of a sudden, that could be a blocked fuel filter which would result in a higher consumption as the fuel pressure goes higher than normal.
It's normally about 40 psi but can go to 70 with a filter blocked.
If you remove the filter and pour some fuel into the outlet most of what's plugging it will run out the inlet port.
« Last Edit: August 25, 2021, 09:34:26 PM by Kiwi_Roy »
« Reply #9 on: August 25, 2021, 06:38:44 PM »
There is an ultimate reason I did it that way, believe it or not.   It was not to be a personal attack, just to spice it up. BUT to get attention to all the questions. It was to draw attention to the thread, otherwise just will get mulled over.
If I'm a Richard then more riders will help you out.
Offline Chet Rugg
  • Administrator
  • Chet & Rusty ( 99 Bassa )
« Reply #10 on: August 25, 2021, 06:44:28 PM »
JC was this after adding the top case? Seems like everytime I added something to rusty ( my 99 bassa)  it got less gas milage. Something to do with more wind drag. bags crash bars windshields . could have been more miles racking up as I was building and needed tuned too I dont know. Oh I also hooked a trailer behind it and that really changed things. Calvin is different than bassa open loop fuel injection a bit different than closed loop. You have 02 sensors I dont so guzzidag or what ever its called may be needed on yours for tweeking it on fuel milage.
Chet
Chet Rugg
99 Bassa
01 Cali Special
100,000 miles
Offline JC85
« Reply #11 on: August 25, 2021, 06:54:48 PM »
Ok, I can appreciate that. And now that I have a feel for how you operate, I know not to take it personally, in the future. Again, no hard feelings on my end, and I hope there aren't any on yours.
'07 CalVin
Offline JC85
« Reply #12 on: August 25, 2021, 07:12:42 PM »
The low fuel light is probably a thermistor or perhaps a float switch, either of these will suddenly move and operate at a different level.
Thanks. I'll make a note of both of those.
'07 CalVin
Offline JC85
« Reply #13 on: August 25, 2021, 07:14:27 PM »
Chet
Thanks for the info, Chet. It actually started, just before I added the top case.
'07 CalVin
Offline JC85
« Reply #14 on: August 25, 2021, 09:13:26 PM »
Ok, guys. After reading and listening to everyone's advice, here are all of the things that I plan to check and replace, if necessary, in order:
Air filter
Plugs
Throttle bodies
TPS
Valve lash
Fuel filter
I'm also considering getting Guzzidiag and purchasing a Beetle map. Terry, the previous owner, wrote his own map for it, and I've just left it alone, as I have zero knowledge of these things. Now, a few questions:
First, can anyone tell me what fuel filter to purchase? I've looked on Mgcycle, and they're sold out of the metal ones, and I can't find the brand that they carry anywhere else. I've also read through several threads about the plastic filter issue, but haven't seen anyone mention a specific part number, brand, etc.
Next, Terry also swapped the original pipes for a set of Harley pipes to eliminate the cats, in order to make it run cooler, and he removed the o2 sensor. If I do swap to a Beetle map, will I need to swap all of that back to original? I have all of those original parts, so it's within my means. I'm just wondering if it will be necessary. I do like the sound of the pipes that are on it and the idea of the engine running cooler, but don't want to change one thing without changing the rest, if it's going to create more problems. Again, thanks to everyone for their input.
« Last Edit: August 25, 2021, 09:27:55 PM by JC85 »
'07 CalVin
Offline PJPR01
« Reply #15 on: August 25, 2021, 09:33:31 PM »
Did you check tire pressures JC?
Brakes?  Is one of the wheels dragging?  Maybe try spinning them and check for excessive rolling resistance?
Does the throttle response feel the same or “heavier”?
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
Offline JC85
« Reply #16 on: August 25, 2021, 09:35:46 PM »
I just had new tires put on it (after this issue started; no change,) and have been regularly checking pressure, since. I pulled and resintalled the wheels, myself, when I had the tires put on, so I can confirm that they spin freely with no drag. The throttle feels as responsive as ever.
'07 CalVin
Re: Calvin Mileage Dropoff and Fuel Light Problem (New Questions)
« Reply #17 on: August 25, 2021, 09:40:06 PM »
My EV gets about 35, at one time it got 40+.
Offline lazlokovacs
« Reply #18 on: August 26, 2021, 04:32:12 AM »
Damn i thought I was the young guy on a Calvin round here! Time marches on...
Re your bike- It could also be that a sensor has stopped working...
If, say, the O2 lamda sensor packs up then the bike defaults to a slightly rich setting...
Could well be the same for the engine temperature sensor and maybe even the air pressure sensor, or ambient temp sensor...
Basically the sensors send a message to the ECU to 'trim' the fuel injection times, if the ECU receives a wide open or closed signal it defaults to a slighter richer setting.
If the PO has uploaded his own map the it's likely that the O2 Lamda sensor has been disabled.
so probably not that...
The engine temperature sensors have been known to fail.
I would suggest getting Guzzidiag, that way you can read what the engine temp and all the sensors are saying, which should help you eliminate a few things.
Keep updating us
Offline delrod
« Reply #19 on: August 26, 2021, 06:26:25 AM »
JC I've got a set of cables. Do you have a laptop to run guzzidiag
Doug in Pittsburg KS
2003EVT
« Reply #20 on: August 26, 2021, 06:34:43 AM »
What color in the spark plug ceramic?
BTW, That is very unlikely to be a 5.5 gallon tank. Guzzi lied if they said it is .
Offline Dave_NWTrophy
« Reply #21 on: August 26, 2021, 09:57:20 AM »
One thing to also check - make sure your odometer is reading correctly.  The ITI gauges are known to strip out the odometer drive gears.  It will start with one tooth skipping, then slowly eat others.   My Cal Titanium started recording mileage at about 5-10% less than traveled before stopping completely.
Dave
« Reply #22 on: August 26, 2021, 10:40:50 AM »
Air Filter-- GU30113600
Fuel filter --Mahle KL-145
Plugs-- Outer BPR6ES   Inner--- NGK PMR8B or CR8EKB(dual electrode)
Valves-- .006" exhaust  .004" intake
Throttle body cleaning can be done by sliding intake tube back into airbox & use bent tooth brush.
« Last Edit: August 26, 2021, 10:43:12 AM by guzzisteve »
Offline JC85
« Reply #23 on: August 26, 2021, 11:50:28 AM »
Awesome, I may see if I can borrow them. I've got an old laptop that has no memory whatsoever, but I can load and run Guzzidiag from a thumb drive on it.
'07 CalVin
Offline JC85
« Reply #24 on: August 26, 2021, 11:52:08 AM »
Thank you! For my own personal knowledge, what's the purpose of having two different plugs for inner and outer?
'07 CalVin
Offline nc43bsa
« Reply #25 on: August 26, 2021, 12:10:25 PM »
I haven't seen this particular engine, but probably because a smaller inner plug was required to fit in the restricted space.
1990 MilleGT
« Reply #26 on: August 26, 2021, 12:22:29 PM »
Keep an eye out for fuel leaks. These tanks can leak from edges or can develop cracks in the tunnel. You’d think it would be obvious, and eventually it will be but they can hide for awhile
« Reply #27 on: August 26, 2021, 12:27:13 PM »
That's it, space. Use PMR's if you like to remove, clean, regap. The CK's are cheaper and toss away but long life.
