Author Topic: Need advice: Fiat 2000--to buy or not?  (Read 1574 times)
Offline yackee
« on: November 15, 2021, 03:40:56 PM »
I am looking at a 1981 Fiat 2000 tomorrow, an older couple that lives about 5 miles from me has owned it since 1986 is eager to get rid of it. It's all original. Like totally all original, 56k. Allegedly runs well.
Price is now at $2,000, they've had it on CL for a month or two but not getting bites. The couple wants it out of the garage to make room.
Thoughts? Pictures show it in good shape, no apparent rust. I've been looking for a convertible akin to my long-gone and much-missed Alfa Romeo Graduate.
Re: Need advice: Fiat 2000--to buy or not?
« Reply #1 on: November 15, 2021, 03:47:45 PM »
For $2K I'd buy it, I had an earlier model right before they turbo'd it. Antenna in front of windshield.
Offline egschade
  • Eric - MGNOC NJ Rep - mgnocnj.forumotion.com
« Reply #2 on: November 15, 2021, 03:49:57 PM »
I had a much older '68 124 Spider. Electronics were fiddly but that 'should' be much better on an '81. Rust in the fenders, rockers and trunk is always an issue. If it's as clean as you say it's worth $2K in body parts alone.
As with Guzzis, your best bet is to find a forum and hit them up for your particular year. You can also do some quick searches for parts to make sure they're available - esp stuff like fuel pump/filter, electronic components, etc.
Post the CL link if the ad is still up.
« Last Edit: November 15, 2021, 03:51:14 PM by egschade »
The elder Eric in NJ
2024 Triumph 400X Scrambler
1971 Honda SL350
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Griso 1200SE Tenni
Breva 1100
EV Touring
Offline sdcr
« Reply #3 on: November 15, 2021, 03:50:43 PM »
If it’s this one, you can’t go wrong at $2000.
https://madison.craigslist.org/cto/d/middleton-1981-fiat-2000-spider/7405519397.html
2000 BMW R1100 RS
1983 BMW R100
2009 Jaguar XK
Offline jbell
  • Some progress
« Reply #4 on: November 15, 2021, 03:54:20 PM »
$2000 sounds like a great price, just be sure rust hasn't eaten away your good fortune. Hope it works out for you.
'76 Guzzi T3   Future project
'78 Guzzi G5  Current project
'81 Guzzi G5  Organ donor
'92 BMW K75RT  On the road
« Reply #5 on: November 15, 2021, 03:55:58 PM »
I looked too, good deal I'd say.
Offline berniebee
« Reply #6 on: November 15, 2021, 04:24:03 PM »
As has been mentioned pay close attention to the rust prone areas. I'd be surprised if you didn't find any rust on an unrestored car by now. Fiat simply left any out of sight metal unpainted. If I remember correctly, there was an issue that mostly affected high mileage Fiat spider's front cross member. Where the lower control arms are mounted, the cross member can crack and allow the arm to to pull right out. The cross member-to-body bolts can come loose and also pull right out. With loose bolts this can happen even at 50,000 miles.
These were great fun little cars. $2k is pretty cheap for a Spider these days, but I'd check it over carefully. Because after two months a Fiat aficionado has probably already checked it out and decided it wasn't worth the price.
Offline rtbickel
« Reply #7 on: November 15, 2021, 04:26:42 PM »
For $2000 that is a great buy.  I had a 78 and they are a blast to drive.  Never had any of the fix-it-again-Tony issues and it was pretty reliable.  Check the lower a-arm bushings and crossmember like he said and for corrosion in the battery box in the trunk.
« Last Edit: November 15, 2021, 04:28:07 PM by rtbickel »
2020 V85TT
Online JJ
« Reply #8 on: November 15, 2021, 04:37:24 PM »
The price almost sounds "too good to be true..." Be sure to ask the owner for any / all maintenance records as well...
Besides the RUST issues mentioned...if it has not been sorted and properly maintained all these years, it could be your worst NIGHTMARE!! :rolleyes: :shocked: :huh:
https://bringatrailer.com/auctions/results/?search=1981+Fiat+2000
« Last Edit: November 15, 2021, 04:39:09 PM by JJ »
Offline Deno
« Reply #9 on: November 15, 2021, 06:01:26 PM »
Sounds like a heck of a deal. Hard to understand how it has not sold in a month at that price.
I am an Alfa guy but have had Fiats as well. Parts are plentiful, or were before the current shortage of everything. Lots of good support on the forums. Fun to drive.
Good luck.
Offline exiledrebel
« Reply #10 on: November 15, 2021, 08:21:57 PM »
I had a 79 and an 80 way back when. They were both good, reliable cars. The Fiat reputation just didn't apply to either of mine. Rust would be the major issue. If that checks out, and it just might, given the low mileage, and it runs well, I would buy it. They're very fun little cars.
« Reply #11 on: November 15, 2021, 09:17:51 PM »
I loved the look of the older cars.  The later cars appear a couple of inches taller and have those ugly bumpers.
I wounder if the newer ones could be make to look like the old ones?   :blank:
Offline sdcr
« Reply #12 on: November 16, 2021, 07:26:36 AM »
Aside from severely faded surface paint on the trunk lid, hood and tops of the fenders, appears to be a straight machine. Probably will need some baseline maintenance to make it truly roadworthy.
2000 BMW R1100 RS
1983 BMW R100
2009 Jaguar XK
Online Groover
    • Scooteropolis
« Reply #13 on: November 16, 2021, 07:54:57 AM »
I'd offer $ 1,995 so it's a clean $ 1 per cc  :azn:
Looks like a great deal to me.
« Last Edit: November 16, 2021, 07:55:48 AM by Groover »
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline yackee
« Reply #14 on: November 16, 2021, 08:13:13 AM »
Yep, that one. My instinct too was can't go wrong.
Offline yackee
« Reply #15 on: November 16, 2021, 11:48:37 AM »
I bought it, am picking it up tonight. No real rust issues I could see, just a tiny bit of surface on one of the runners, and the engine ran quite smoothly with good around-town power. It seemed pretty low risk for $2k. Family had owned it since 1986. Still had the original 40-year-old top. I'll have to decide whether to try to get it in to the shop for an initial inspection and any basic maintenance issues before the snow hits (always happens around Thanksgiving here in the Great White North) or whether to store it till spring. It will definitely need new shocks, and probably some brake work at a minimum, along with new (13 inch!) tires.
I did some research on parts availability, and, hard to believe, but everything you could want seems readily available from multiple state-side sources and inexpensive to boot.
Offline sdcr
« Reply #16 on: November 16, 2021, 12:33:07 PM »
Congrats, that one looks to be worth saving. If you have any electrical gremlins, it may just be corroded connections and poor grounds. Start there, with DeToxit, and you should be OK.
The fact that it has virtually no rust is the most important thing.
2000 BMW R1100 RS
1983 BMW R100
2009 Jaguar XK
Online Groover
    • Scooteropolis
« Reply #17 on: November 16, 2021, 01:24:52 PM »
I looked into those a few years ago, agreed all parts are pretty easy to find. The red interior pieces are a little harder to find as reproductions, but the beige, black and blue interior parts seemed to be easier to source.
1980 Vespa SI Moped
Offline Deno
« Reply #18 on: November 16, 2021, 01:43:06 PM »
Great deal and good luck.
The Fiat National convention will be in Houston in September 2022. This is a great club with all sorts of age groups.
Join the Mirafiori Forum. It is all Fiats but the main focus is the 124.
