Delinking brakes
Topic: Delinking brakes (Read 1377 times)
dxhall
Delinking brakes
April 27, 2022, 04:06:55 PM »
I’m rebuilding an SPIII. I want to de-link the brakes, but am tempted to cheap out and use the stock rear master cylinder with a later 32/30mm caliper from an EV. The stock MC is 15mm bore. I don’t know what the stock MC size was on the EV. Any sense for what the pedal travel will be?
Last Edit: April 27, 2022, 04:37:28 PM by dxhall
Caffeineo
Guzzi B00b
Re: Delinking brakes
Reply #1 on:
April 27, 2022, 08:17:36 PM »
This may help.....a chart showing different combinations of master cylinder piston size and wheel cylinder piston size to get good brake feel.
http://www.vintagebrake.com/mastercylinder.htm
2022 Moto Guzzi V85
2023 Husky TX300
2020 KTM 500 XCW
dxhall
Reply #2 on:
April 27, 2022, 08:49:08 PM »
That’s an interesting table. Would you use the same “sweet spot” number for the rear?
guzzista
Reply #3 on:
April 27, 2022, 09:04:04 PM »
The 15mm master cylinder is actually 5/8 or 15.875. With the front brake line plugged off, the pedal stroke will be very short regardless of which caliper. As the force applied by the foot is strong(er than a hand) , it might work OK for you anyway.When I delinked my LM1 I used one of those below. The original cap with the switch swapped in IIRC , and the lever pivot was turned around as well as new way to hook up the return spring. . The feel was lighter due to the 1/2 inch master bore which is what I was looking for
https://www.ebay.com/itm/363298063045?hash=item54964082c5%3Ag%3AFcEAAMXQ56ZR%7ECQj&LH_ItemCondition=1000
Last Edit: April 28, 2022, 09:42:38 AM by guzzista
Dukedesmo
Reply #4 on:
April 28, 2022, 07:56:25 AM »
I also used the above mentioned master cylinder from a same era Italian (Ducati, Laverda etc.) on my de-linked LM2 as it fits (with some slight modification) and works just right on a de-linked rear due to the smaller piston. I didn't bother with the fluid level cap as it just seemed unnecessary.
I used a 15mm master at the front to power both front brake calipers and, again that's the perfect ratio IMHO.
Le Mans II
Ducati 916
Ducati M900
dxhall
Reply #5 on:
April 28, 2022, 08:12:29 AM »
Thanks for the help. I’ve ordered the one from eBay - that should be better than the stock setup or the modern MCs with the different mounting arrangement.
Dukedesmo
Reply #6 on:
April 28, 2022, 09:40:32 AM »
If the mounting is the same as a LM2? then you will need to lightly modify it to fit as it sits 'backwards' compared to the 'Ducati fit'. Basically need to alter the counterbore in the holes and make some spacers IIRC but, otherwise it is perfect not least because it is the same design as the original.
Le Mans II
Ducati 916
Ducati M900
Dukedesmo
Reply #7 on:
April 28, 2022, 10:27:00 AM »
With regards to the mods required, here is some more info;
https://wildguzzi.com/forum/index.php?topic=91902.msg1451175#msg1451175
Le Mans II
Ducati 916
Ducati M900
Delinking brakes
