Author Topic: Selecting circuit to add driving lights  (Read 1351 times)
Offline Burkslaw
« on: May 16, 2022, 06:19:53 AM »
I'd like to add an LED driving light to my 2002 Jackal. Even though the light doesn't draw much current I'll use a relay. In order to energize the relay I'd like to find a circuit that is hot only when the key is turned on, so that I can leave the driving light switch in the "ON" position even when the bike is shut off.
I have an "Add A Circuit" fuse holder which would plug into one of the fuses under the side cover and allow me a fused hot source. Any suggestions as to which circuit I should tap into?
Offline OldMojo
  • Career of Evil
Re: Selecting circuit to add driving lights
« Reply #1 on: May 16, 2022, 06:52:08 AM »
On my EV, I tapped into the circuit for the little "parking light" bulb in the headlight bucket. Depending on your wire routing, the taillight circuit will work too.
'15 Griso 1200
'14 California Tour
'02 California EV
'80 CB 650C
Online moto
  • Fear the deer!
« Reply #2 on: May 16, 2022, 07:46:35 AM »
OldMojo's advice is right. On Guzzis of your era, the wire is yellow, both going forward to the parking light and backward to the tail light.
850 T-3
Griso 1100 corretto
« Reply #3 on: May 16, 2022, 08:40:01 AM »
As mentioned, I have tapped into the little parking light in the headlight bucket on a number of Guzzis. You of course still need a long fused wire off of the battery to feed the relay contact.
« Reply #4 on: May 16, 2022, 10:54:50 AM »
As others have said the parking light circuit and you don't really need a relay.
A pair of spots at 10 Watts each is only going to draw 2 Amps and the lights typically operate at full brightness from 9 - 30 Volts
In other words you can afford to lose 3 Volts, at 2 Amps you shouldn't lose half that.
On my V7III I have 2 spots fed through 2 Amp reed switches so I can turn them off by removing a small magnet stuck to the outside of the headlight bucket.
Horns on the other hand do need a relay if you want them to be loud need to be mounted on the spring steel bracket they come with.
The small Blue/Black pair of wires are also from across the park light and go to the battery Voltmeter.
If you are still going to use a relay power the coil up from the park light (yellow wire), you don't need to add a fuse there but use a 5 Amp fuse to supply the 30 terminal, there is lots of room in the headlight bucket for the relay and fuse and you don't have to cut into the main loom.
https://www.thisoldtractor.com/guzzi007/schematics/2000_Jackal.gif
Note how the red wire to the ignition switch and the brown wire back to the fuse block is completely unprotected, this is very typical of Guzzi looms, I usually add a large fuse e.g. 40 Amps at the battery end.
« Last Edit: May 16, 2022, 01:12:54 PM by Kiwi_Roy »
Offline Burkslaw
« Reply #5 on: May 17, 2022, 06:44:57 AM »
Tapping into the parking light supply wire should have been a no-brainer for me. Works perfectly. Thank you
