the Cali 2 has the later tall neck (Tonti) frame , so to fit later forks no problem with the steering stem. The fork spread remains the same at 195mm up to 1997 Cali 1100 for the easiest swap , a 40mm Cali3/ or 1100 complete fork would be easiest both for the front fender attachments and the 300 mm brake disk/ caliper configurationYou might have to trim the hub in order for the discs to have a 4-5 mm clearance with the inside of the fork legs. Your axle will work but minor spacer adjustments may be required
