Author Topic: Starter switch, throttle assembly  (Read 1333 times)
Offline Dan Beaman
  • SW Iowa....no we don't grow potatoes here!
« on: July 01, 2022, 01:06:02 PM »
After digging through every wiring scenario I could think of on why my '81 G5 wouldn't turn with my starter switch, I finally realized the issue is my starter switch itself. How do you get the the throttle itself out of the starter/kill switch electrical housing and how do I get it IN the new???
Or do I have to do separate units?
« Last Edit: July 01, 2022, 01:16:32 PM by Dan Beaman »
MGNOC L797
'81 G5
'98 EV
Offline centauro
Re: Starter switch, throttle assembly
« Reply #1 on: July 01, 2022, 02:02:07 PM »
If your throttle/switch assembly is the "lego" style, there are 2 tiny, slotted screws under the unit that, once removed, will split the unit into halves. You'll need a small 1/8" blade common screwdriver.
That is what I had on my '84 SP 1000, and the switch went bad, as well.
What I did, once it was apart was to take a hack saw and cut off the switch part of the throttle. Then I bought this, or similar to replace starter and kill switch unit:
https://www.amazon.com/gp/product/B07GNBRJ6C/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
The throttle part of the unit was not affected.
Val Barone
1984 1000 SP/NT (sold)
1985 Vespa PX150E
1973 Honda CB 350 Four
Offline Dan Beaman
« Reply #2 on: July 01, 2022, 02:59:37 PM »
Ok....that worked in getting apart very well. How did you get the throttle assembly to stay put? Just friction?
MGNOC L797
'81 G5
'98 EV
Offline centauro
« Reply #3 on: July 01, 2022, 03:23:11 PM »
The throttle plastic drum just rests in the "cradle" of the bottom shell. Just disconnect the cables first to make it easier to reassemble; a little grease around the throttle would not be a bad idea at this time. Then reinstall the cables after the 2 halves are back together.
Val Barone
1985 Vespa PX150E
Offline guzzista
« Reply #4 on: July 01, 2022, 03:46:55 PM »
Unless you are going the Concourse correct route, you could upgrade the whole thing and use separate units .
The Detomaso era Lego  switches did  well given how low budget they were built, but starting/ kill switch and throttle are safety and reliability  items so  with that in mind , here are some new available items for the job. That way you will have a new switch as well as a metal dual throttle
https://www.mgcycle.com/index.php?main_page=product_info&cPath=131&products_id=739
https://www.mgcycle.com/index.php?main_page=product_info&cPath=37_140&products_id=4898
« Reply #5 on: July 01, 2022, 03:58:04 PM »
There should be a tiny set screw on the underside that locks the unit to the handlebars.
I use this right-side switch on my Convert: https://www.mgcycle.com/index.php?main_page=product_info&cPath=37_140&products_id=2592
« Last Edit: July 01, 2022, 03:59:38 PM by Antietam Classic Cycle »
Offline Dan Beaman
« Reply #6 on: July 01, 2022, 07:05:40 PM »
I ordered that very switch assembly, but I'm doing what centauro saidvabout cutting it apart. It worked!
MGNOC L797
'81 G5
'98 EV
