The MyECU that I have has a dashboard w/readout where you are on map, and you can change it, in real time.I got a newer version on my tablet, it also has logging.I have done this stuff going down the road, I do not advise it.I like the way you raised scale.
charge transfer and valve overlap mean that those AFR numbers are not always accurate....What we want to know is what's happening within the combustion chamber, what the AFR tells us is what's in the exhaust a nanosecond later. Not necessarily the same thing. I believe the 1200 engines are particularly difficult to map by AFR aloneDo post up all the results though, as stated above, empirical data is always welcome.What map are you running currently?
